How to make items visible but inaccessible in a dropdown
Jul 31, 2012 1:31 PM
Tags: #javascript #livecycle #scripting #livecycle_designer #formcalc #livecycle_form #livecycle_forms
I have dropdown1 with items1-3.  I have dropdown2 with items 1-10.  When item1 is selected in dropdown1 I want dropdown2 to display all 10 items but some items be inaccessible(faded out) and not selectable.
(example)
item1  =    [dropdown2] item 1 = selectable
                [dropdown2] item 2 = selectable
                [dropdown2] item 3 = selectable
                [dropdown2] item 4 = not selectable
                [dropdown2] item 5 = selectable
                [dropdown2] item 6 = not selectable
and so on.
I have coded dropdown2 to populate based on items selected from dropdown1 but the problem is the user needs to see options that are not available for selection?
I am very new to FormCalc & Java any help would be greatly appreciated!!  I am using LiveCycle Designer ES 8.2
    Aug 1, 2012 9:43 AM   in reply to Jstout101
    you can do this with a script in the change event of the drop down box.
    It will check the boundItem against the notUsed regular expression.
    This example won't allow the selectio of item 1, 3, 4 and 8.
    var notUsed = /1|3|4|8/;
    if (this.boundItem(xfa.event.change).match(notUsed)) {
              xfa.event.change = "";
    Aug 1, 2012 10:47 AM   in reply to Jstout101
    i made an example for you.
    https://acrobat.com/#d=e7uz6IaYn0YpgsnNcFfvlg
