We have had a recurrent problem with InDesign crashing when trying to update files that have been edited in InCopy. We can work around the problem by finding the few (sometimes one, sometimes several) ICML files that are causing the crash and unlinking. We can then re-export and continue on our merry way. We have tried the requisite deleting of preferences, exporting to IDML, etc., but those things do not help.
Support has not been helpful so far, even saying that they do not recommend using these programs over a network!!! I hope that's a miscommunication issue.
Digging a little deeper, everytime it crashes, it generates a ProtectiveShutdownLog: this log shows 4 APLN that did not load (see below). (This could be correlation, but not causation) Hoping someone from Adobe can jump in and offer some real support.
Adobe InDesign Protective Shutdown Log
06/27/12 08:38:45
Unhandled error condition
Session started up at 8:37 AM on Wednesday, June 27, 2012
Version: 7.5.3 - Build: 333
Error Code 0x20705: "The content is locked and cannot be modified."
Called to process command 0x21a
Command Processor Stack (from top to bottom):
9. Command 0x13513 "Create Hyperlink Text Destination"
8. Command 0x7304 "Import File"
7. Command Sequence "Import File"
6. Command 0x730a "Import File"
5. Command Sequence "Re-import File"
4. Command 0x7314 "Re-import File"
3. Command Sequence "Update"
2. Command 0x8c59 "Update Link"
1. Command 0x8c9f "Update Link"
Registered plugins:
Name ID Version Build Load Status
POSITIONTOOL.APLN 0x19b00 7 5 Load Failed
EDITOR HELPER UI.APLN 0x21101 7 5 Load Failed
INCOPYCOREUI.APLN 0x21201 7 5 Load Failed
INCOPYFILEACTIONSUI.APLN 0x21301 7 5 Load Failed
OK, update today. After discussion with Adobe Support, it appears that this is a "known issue" and that the workaround is to move the INDD and ICML files to a non-shared drive before opening them in InDesign. We will incorporate this practice and see if it solves the problems we have been having.
I thought InCopy was designed to work with InDesign in a collaborative/network environment, so this workaround doesn't make sense to me.
Are ######there are other users of InCopy and InDesign that store and work on their files on a shared network drive? If so, I am interested in hearing about your workflow and if you are having file update problems.
J
Still experiencing this issue, though my great IT person has narrowed down the problem and will work with "Support" to try to get a better fix. From my IT department:
"We have made a little more sense of the madness. It looks like the third InDesign 5.5 update, version 7.5.3 , is the cause of our woes. When I run our broken InDesign/InCopy file on a machine that only has the version 7.5.2 update there seems to be no issues updating the file in InDesign. Take that same file and try to open it on any machine that has the version 7.5.3 patch installed and it crashes mid-update. I’m trying to get in touch with adobe tech support again to let them know about the discovery and hopefully pinpoint what in the patch is causing the crash. The InCopy software can be completely updated with no problems arising. The problem is strictly related to the InDesign 5.5 version 7.5.3 patch. I think the problem can be fixed so long as we keep the machine in a pre 7.5.3 patch state, but this is only a temporary solution because there are Information Assurance issues not keeping the software up to date and eventually we will be forced to update our software. When we do, documents will start breaking again so it’s vital we find a more permanent solution. Perhaps Adobe can find a fix for this issues or include a fix in a later patch."
It's an interim solution. We are downgrading now. I had a file with issues updating in both IC and ID 7.5.3, switched to ID 7.5.2 and IC 7.5.3 and it updated fine.
I say interim solution because I can only convince my IT guys that I have to keep out of date software for so long. When IT makes me upgrade, I am certain the problem will return. Hoping for a fix in the software itself.
I have no idea why we would have an issue and others would not.
J
I just upgraded to InDesign 8 (CS6) and I am experiencing some instability with certain InCopy documents. My colleagues are still using InCopy CS5. When placing some, and updating already placed InCopy documents InDesign will shutdown due to a "serious error".
For the record, these InCopy files do not exist on networked storage. Technically, I am using Dropbox to share files with colleagues but those files are hosted locally of course and the issue doesn't have anything to do with currently syncing files, etc.
If no one has any thoughts I suppose I will upgrade InCopy to CS6 and throw another new variable into the mix to see what happens.
No change. Opened InCopy CS5 document in InCopy CS6, saved as a new document. Chose Relink in InDesign document. Same crash-inducing, serious error. (The InCopy document, by the way, is simply text with a few paragraph styles — I won't get into InCopy documents with graphic anchors, etc.)
Creating a new InCopy CS6 document, copying content from existing InCopy CS5 document and pasting content into new document also produces same crash as does attempting to place this (or previous iterations) in a new InDesign CS6 document.
But, placing InCopy CS5 or InCopyCS6 document in a new InDesign CS5 document (running both versions concurrently) is successful.
I am having the same problem with the InDesign/InCopy workflow crashes. I work in a windows network environment.
I have just suggested to my IT person to re-install my InDesign software (I currently have InDesign CS5.5, v7.5) and do the update suggested in the InDesign forums (7.5.3 available since May 2, 2012 in the Adobe site.
Has anyone experienced the results of this update as to solving the problem or not?
Does the version combination suggested by Anne Marie resolves the problem?
Any assistance will be appreciated :-)
AM, this is Rocio... yes THAT Rocio... experiencing this very frustrating problem with the ID/IC workflow that used to work so well until a few weeks ago.
So, here I am now asking if the combination you suggest is the 'winning combination'... did you got to know the answer to your question? If so, I would like to know how that worked. :-)
Rocio,
Our trouble started when we installed ID 7.5.3. When we went back to ID 7.5.2, the problem went away. We are running IC 7.5.3 and ID 7.5.2 with minimal issues.
One thing that comes up occasionally is that IC will crash when updating links (the opposite as it was before). If that happens, we update the links in ID 7.5.2, clear the Caches folder on the IC computer, and re-open. Works like a charm.
Thanks to Anne Marie for sorting through our posts and summarizing the working combination. I think it would have been lost in the weeds if she hadn't done that.
Good luck, I hope it works as well for you as it has for us. (And that Adobe has more fuel to fix their recent ID patch.) We have an open tech support regarding this issue, since my IT people get grumpy if we run out of date software.
J
JA Flint, thanks for the information! :-)
You have saved me lots of running around in circles! I am passing this information to my IT people and we will be looking to have the version combination you are suggesting and see how it goes. At the same time, I will keep an eye on the other ID/IC workflows in our department to check how are they working with their own software versions. Now, I am curious to know which versions are they working with.
Later on, I will report on the results from implementing from your advice to assist other possible users looking for a solution to this issue. Also, as you mentioned, hopefully Adobe will fix this issue so that we can move forward with new software versions. At this time, if IC 7.5.3 and ID 7.5.2 work well and the issue is fixed, we will probably not be installing newer software until the issue is fixed at the software level with no need of work-arounds.
Thanks again! :-)
I just wanted to add in my 2 cents here. I've been experiencing this problem since the aforementioned update to InDesign CS5.5 and it has carried through to InDesign CS6. It has rendered InCopy almost useless and from what I can gather I'm not alone, not only from the comments in this thread but from the thread at via the link below along with other forums around the place...
http://boardreader.com/thread/InDesign_crashes_when_updating_InCopy_IC _1wt6vXeedo.html
Adobe needs to really get to the bottom of this issue. InCopy was a really useful cross-collaborative tool, it both sped up our internal workflow and minimised editing errors caused by manual insertion of markups on the design end. Now it's joke.
We are also having major problems with our InDesign/InCopy layout and assignment workflows in Win 7, have contacted IT support and still no help going forward.
The recent upgrade to both InDesign and InCopy CS6 (both have the latest patches installed) has not helped, our workflow uses both shared network and dropbox, neither seem stable.
We have posted similar Proectiveshutdown logs, see below
02/04/13 10:40:22
Session started up at 10:39 AM on Monday, February 04, 2013
Version: 8.0.1 - Build: 406
Called to process command 0x7313
8. Command Sequence "Re-import File"
7. Command 0x7314 "Re-import File"
6. Command Sequence "Update"
5. Command Sequence ""
4. Command 0x8c59 "Update Link"
3. Command 0x18e38 "Relink Story"
2. Command Sequence "Relink Story"
1. Command Sequence "Update Story"
The problem always seems to be the same after a simple editorial change to the .icml files.
Adobe need to sit up and pay attention to the problems we have been experiencing.
When I saw the updates to both InCopy and InDesign included apparent fixes for issues related to the importing of .icml files crashing InDesign (the fix was for a supposed issue with Pantones?) I too was hoping that my days dealing with this issue were over.
On the initial setup of my last project where InCopy was needed to cross collaborate with our editorial team everything seemed to be working fine. However much like previous experiences something occurs and suddenly when trying to update .icml files CS6 shuts down due to the 'Serious Error'.
This issue has been been ongoing now for far too long.
I still experience issues with this as well, and I think I was one of the original posters. I thought I would take a second to "bump" my experience and crude fix in the forum.
For me it seems to be a problem with InDesign gathering hyperlink destinations. InDesign will include these URLs, appending them to InCopy files that are getting edited and checked-in in InDesign. From there something happens where a URL can start duplicating, many hundreds of times during subsequent check-out/check-ins.
I sometime examine the InDesign document's destination options deleting the unnecessary ones.
More importantly, I now use Apple OS X Smart Folders in the Finder to monitor production folders for .icml files over 500KB (for my purposes — magazine articles — basic InCopy files that are just text in nature are typically well below 300KB).
If I see an InCopy file is behaving badly (bloating in size unexpectedly) I will open it in a simple text editor and remove the excessive Hyperlink Destination XML elements and save those changes to the XML. This generally fixed the problem.
I hope this makes sense, and might be of use. I realize the previous poster's comments might be more about chiding Adobe for not fixing the issue than looking for someone to chime in with their observations.
I am not sure they are exactly the same problem. We have been able to take "broken" files from ID5.5 and bring them into ID6 (as a test case). The files were not "broken" in ID6. I suppose it could be that ID6 fixes those files, but if an ID6 file gets "broken" you are back to the same problem...it's all very strange.
Regardless, we will continue to use ID 7.5.2 and IC7.5.3 until this all gets sorted out, or I am forced to upgrade. (But I am doubtful that there will be a fix, given how old this problem is).
I believe I may have some insight to share on this problem.
I produce a magazine in InDesign CS6, and the editors use Incopy over a shared dropbox account.
As we start creating articles, I usually export them to Incopy one by one, just the text frames that I expect them to edit. However, at some point in production, it becomes necessary to unlink all of the Incopy stories, delete those links, and then create clean links - usually because another designer wants to be able to copy text boxes and move all the pages around and having everying linked in Incopy makes that more cumbersome.
When it's time to remake the Incopy links, I have several times tried using "Export all stories" to create them all at once. DON'T DO THIS. I believe this is one of the main causes of the problem because there are various pieces of text that you don't want linked via Incopy - such as master page footers, section markers, anchored text elements, text labels on a digram that are in small round text boxes, and so on. I think these are the things that cause the crashing when you try to update an Incopy link - even if the one you're updating has none of these features.
So, instead, after a clean sweep of all linked text, I now re-export the Incopy links manually. I go one spread at a time, and highlight all of the relevant text frames at once, and export to Incopy. That way I know I'm only exporting the frames that have the main text in them that will be edited, and not the "decorative" text or locked items.
This may be prohibitevely time-consuming in some projects, but until Adobe is able to fix the application, I believe it's one way to solve the problem. Seems to help on my magazine.
