clytus
Can't print from InDesign CS5 under Mountain Lion
Aug 1, 2012 11:48 AM
Tags: #problem #cs5 #crash #mac_os_x #printing #print
After installing MacOS 10.8 InDesign crashes when I try to open the printer configuration in the printing menu. Acrobat crashes immediately when I want to open the print menu. Photoshop prints fine and PDF export in ID also works as well as printing without changing the former printing  settings.
In an older discussion I found the hint to delete some language folders in the PPD ressources folder to solve the same problem in CS3 and 4 with Lion. I tried that to but it won't work.
Any ideas? Thanks in advance
  • Rob Day
    Oct 16, 2007
    Aug 1, 2012 12:16 PM   in reply to clytus
    If changing the print settings crashes ID I wonder if you need to delete and reinstall your printers? Testing CS3 I wasn't able to even open the Print dialog without crashing, so  deleteing the foriegn language PPDs worked
    By default Mountain Lion hides the user Library (you can't see user/Library/Printers). You can get to it via Go>Go to Folder and typing ~/Library
