zipmichael11
Export Blur Problem
Aug 1, 2012 10:36 AM
Tags: #export #1080 #motion #blur
Hey guys,
Quick question, thanks in advance for the help.
Watch this in 1080: http://www.youtube.com/watch?v=Xa58U-m07X4&feature=youtu.be
It's only apparent in the 1080 form.
Every moving object (the characters running, for example) comes out blurry. I'm new to premiere but I have CS6, I exported according to what was suggested by the sequence and footage. I tried deinterlacing but that didnt change it.
What do I do?
THANKS!
    Aug 1, 2012 12:03 PM   in reply to zipmichael11
    What was your source footage? Was it progressive to begin with?
    I'm assuming it isn't since you said you tried deinterlacing although I'd just like to make sure before I give a answer. It looks like there is some type of interlacing issue occuring. Anyways though tell me your exact sequence settings, frame rate and source footage attributes and also your exact current export settings you used. Also did it look okay before you uploaded it to youtube?
    Then I will do my best to give you a possible answer.
    Aug 1, 2012 12:12 PM   in reply to zipmichael11
    What is the final destination of your footage?
    If its Youtube use a YT preset or a HDTV preset.
    These presets export automaticly to progressive.
