I needed to make changes to a recently finished 5.5 project. It was my first attempt at using the Adobe Dynamic Link function which basically treats a Ae composition as if it were a sub comp (or nested sequence) in Pr. This worked pretty good in Pr 5.5, all changes I made to the Ae 5.5 comp were quickly updated (or refreshed) in the nested sequence in Pr 5.5.
Unfortunately, in the mean time I had updating to Pr 6 and Ae 6. There were several issues with the converted Ae 6 project (previous animation presets were not working anymore). I fixed these fairly easily by adding the presets again from the the effects pallet, the key frames worked still miraculously.
The more annoying issue was that the refreshing of changes made in Ae were not showing up in the Pr project. They where there, but not visible. When exported the exported sequence's changes matched those from the Ae comp.
I couldn't find a command to empty the render cache in Pr, so I just trashed the render files from the finder level (the folder with the render files is in the same path as the project file). That worked. I had to rerender everything, but at least the changes from Ae were visible. I have reported this as a bug.
Cheers,
DK
Make sure you SAVE in AE before toggling back to PrP.
Delete the render files and re-rendered the entire sequence.
or try to use http://helpx.adobe.com/x-productkb/multi/startup-screen-hangs-premiere -after.html
Hope it helps
Hi Techkid,
Thanks for the suggestions. I do save before toggling (mainly because if you don't and then quit the Ae project without savinging you have a big mess on your hands), even though in Pr 5.5 with Ae 5.5 that wasn't realy necissary. The changes just updated like magic.
The workaround for this problem is to manually delete the render files and rerender everything. I think the idea was that you would just need to render the changes.
I'm guessing that the new "global performance cache" funktion is causing the problem. It looks like Pr is not getting the information about the changes from Ae. A classic case of a good function turning into a good headeche. The function is causeing exactly the type of delay it was designed to eliminate.
It would benice to know if others are having the same issue. It could be just me...
Dynamic Link CS5.5, is not compatible with Dynamic Link CS6. You can import an AE CS5.5 legacy project into PR CS6, or open a PR CS5.5 legacy project that contains comps from an AE CS5.5 project in PR CS6. But if you want to make changes in AE, and have the PR project update to reflect those changes, you need to overwrite the legacy AE CS5.5 project. For example, open the PR legacy project, in PR CS6. Select one of the AE comps, and choose edit original. When the AEP opens, save it using the same name, to replace the 5.5 version with a CS6.
Here is another workaround that may be a bit easier.
Add an adjustment layer above your AE comp in PPro, and add an effect to the adjustment layer (three-way color corrector is a good one that won't make any actual changes to the adjustment layer, unless you actually change settings). This will force the layers below to unrender, and allow you to see the updated AE comp.
