akelsall
Can't remove watermark...
Aug 1, 2012 3:06 PM
I have a PDF that I need to remove what looks like a watermark across each page, but using the "remove watermark" feature in Adobe X Pro does not remove it. What else can I try to get rid of
what looks like a watermark on each page?
Andy
    Aug 1, 2012 3:11 PM   in reply to akelsall
    Try selecting the object with the Select Object tool and deleting.
    Tools > Content > Select Object
    Aug 1, 2012 3:17 PM   in reply to akelsall
    The "Remove Watermark" feature only removes watermarks that were created by Acrobat. If the watermark is not an Acrobat one, you can just delete the object with Steve's method.
    Aug 1, 2012 3:44 PM   in reply to akelsall
    This could happen if the file was locked, so you couldn't edit it.
    If it was editable, this is how it would look when you select the object. There would be a rectangular bounding box around it. When you hit Delete, it would disappear.
  • George Johnson
    Aug 11, 2002
    Aug 1, 2012 3:59 PM   in reply to akelsall
    You should use the Edit Object (or perhaps Edit Document Text) tool, not the Select Object tool.
    Aug 1, 2012 4:22 PM   in reply to George Johnson
    You're right, George! I was using Edit Object tool but calling it Select Object. Confusing naming, I'm afraid, and fell for it.
  • George Johnson
    Aug 11, 2002
    Aug 1, 2012 5:16 PM   in reply to akelsall
    It sounds like the entire page is an image, in which case you should be able to edit it in Photoshop if you have it, or maybe use the Redaction tool to remove the parts you don't want. If you can post a sample somewhere we will know for sure what you're dealing with.
  • David Kastendick
    Apr 7, 2010
    Aug 2, 2012 8:46 AM   in reply to akelsall
    You could try to save the file as a Word document, check to see if you can then grab and delete just the watermark, then convert the file back to PDF.  I've seen that work in instances like this.
    -David
