CQ5
kentkadim
Dispatcher in same box with Publish Server
Jul 29, 2012 8:19 PM
I am new in CQ5.
Is there any side effect/potential issue if I have a Dispatcher in the same box with a Publish server?
Assuming there will be 3 boxes, 1 Author and 2 Publish servers (with Dispatcher in one of them).
Thank you for the help.
Kent
    Jul 30, 2012 5:47 AM   in reply to kentkadim
    You could have both the publish & dispatcher instances on the same machine if this machine have enough power.
    Generally for security & you use dispatcher to gain Increased response time, fail-safe coverage & flexibility. The publish instance is usually inside the firewall and calls to it are through the dispatcher which is in DMZ.
    In case both Publish & dispatcher in same box, make sure there is firewall setting to avoid direct access to publish instance from external network.
    Aug 1, 2012 5:56 PM   in reply to kentkadim
    Static content is handled with exactly the same speed and ease as on a static web server. For dynamic content it really deponds on your architecture. So far I have not seen any performance or resource issue in web server due to include of dispatcher apache module/isapi filter.   One of load testing report that includes resource sizes at
    http://www.webperformance.com/load-testing/blog/2011/11/what-is-the-fa stest-webserver/
