Can't uninstall update or install Flash Player
Aug 1, 2012 12:48 AM
Tags: #flash_player #install_failed #flash_player_11 #installation_failure
I use Windows 7 64bit, Internet Explorer and Firefox. I had Adobe Flash Player 10 installed but updating did not work anymore. So I tried to uninstall Flash Player with no success (I got the same error). I deleted the Flash folders in %appdata% and tried to delete C:\Windows\SysWOW64\Macromed\ but I can't delete Flash10l.ocx (I tried it in Windows safe mode too). I renamed C:\Windows\SysWOW64\Macromed to Macromed.old and did a restart. Firefox tells me there is no Flash plugin installed anymore. I downloaded the Adobe Flash Player 11 installer (DLM version and manual version) but I get the same errors again:
The installation encountered errors:
No error information is available.
FlashInstall.log contains:
=O====== M/11.2.202.235 2012-08-01+07-16-37.975 ========
0000 [W] 00001113 C:\Windows\SysWOW64\Macromed\Flash\\* 3
0001 [I] 00000010 "D:\Downloads\install_flash_player_32bit.exe"
0002 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/Version 2
0003 [E] 00001039
=X====== M/11.2.202.235 2012-08-01+07-16-41.782 ========
=O====== M/11.2.202.235 2012-08-01+07-16-48.796 ========
0000 [I] 00000010 "D:\Downloads\install_flash_player_32bit.exe"
0001 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/Version 2
0002 [E] 00001039
=X====== M/11.2.202.235 2012-08-01+07-16-50.434 ========
=O====== M/11.3.300.268 2012-08-01+07-29-45.188 ========
0000 [I] 00000010 "D:\Downloads\install_flash_player.exe"
0002 [E] 00001039
=X====== M/11.3.300.268 2012-08-01+07-30-04.447 ========
=O====== M/10.3.183.20 2012-08-01+07-35-31.371 ========
0000 [I] 00000010 "D:\Downloads\install_flash_player_10_active_x.exe"
0001 [E] 00001039
=X====== M/10.3.183.20 2012-08-01+07-35-34.086 ========
I would be very happy if somebody can help me or give me some advises how to install Flash Player...
    Aug 1, 2012 2:03 AM   in reply to Jack_Steel
    Thank your for supplying complete information.
    Can you try the following:
    To delete that recalcitrant ocx file in the old folder, try using Unlocker.
    Aug 1, 2012 6:11 PM   in reply to Jack_Steel
    Just to confirm: you do run the installer as an Administrator user?
    Aug 2, 2012 1:20 AM   in reply to Jack_Steel
    I have asked someone from the Adobe installer team to have a look at your problem.
  • Chris Campbell
    May 4, 2010
    Aug 2, 2012 3:28 PM   in reply to Jack_Steel
    We might be dealing with a permission issue here.  Can you try the steps in the following FAQ?
    How do I fix Windows permission problems with Flash Player?
    If you still encounter problems, please go through steps 1 - 5 in this post (see reply 15 by me) and either paste the log contents to a reply or email them to ccampbel@adobe.com?  We'd like to get a better idea what's going on with your folders and files.
    Chris
  • Chris Campbell
    May 4, 2010
    Aug 7, 2012 7:09 PM   in reply to Jack_Steel
    Could you try manually deleting the following folders, then trying again.
    C:\Windows\system32\macromed
    C:\Windows\syswow64\macromed
    I'll ask on my end if our installer folks can tell if we're having issues writing registry entries given your install log.
    Chris
    Aug 8, 2012 12:10 AM   in reply to Jack_Steel
    One more thing to try; run the uninstaller again, then download and run the MSI installers from http://www.adobe.com/products/flashplayer/distribution3.html
    Aug 8, 2012 2:14 AM   in reply to Jack_Steel
    Wow - great!  Sorry it took me so long to think about that...
