System for serious multicam work?
Jul 22, 2012 12:59 PM
Tags: #system #p2 #multicam #dnxhd
Hello everyone,
I am planning to build a new editing workstation for serious multicam work. I have read lots of discussions here, in Premiere hardware forums, but didn't find help. Sorry, if my research wasn't complete.
Serious multicam - it means in my case 8-10 camera footage (10-bit, 4:2:2), some of them are AVC-Intra100 (P2 cards) and others DNxHD (220Mb/s, recorded by BMD Hyperdeck Studio). Is it possible to build up a system, which can handle all this footage in multicam work (CS6), flawlessly, in real time, or is it just my wet dream for now...?
Planned budget for this system is 6-8k €.
PS! Currently I don't have BMD Hyperdeck Studio - I've heard, that DNxHD wrapped as MXF files are not supported in PPro (even CS6). Is it true?
    Jul 22, 2012 1:28 PM   in reply to taunouibo
    For those kind of workflows, the budget is a bit tight IMO, but you may get by with something like I'm building now: Adobe Forums: Planning / building a new system. Part 1 but I would consider either an OC'ed 3960X or a dual E5-2690 in this case. Definitely have a serious look at my intended disk setup.
    Jul 23, 2012 5:10 AM   in reply to taunouibo
    With say 10 tracks in a multicam situation using AVC-Intra 100 and DNxHD, you are pumping around huge amounts of data. You are correct that the codec is an easy one, but the amount of data is really huge. So you need a very fast array to get to all those data and dual E5-2690's have the advantage of have much more cores (2 x 8 plus HT) but even more importantly, they have 2 x 20 MB L3 cache instead of only 15 MB L3 in the 3960X. However, the lack of overclockability and the enormous price difference, including a much more expensive mobo, can well be a stopping factor.
    With my intended disk setup, I hope I can manage to remain in a € 6 - 7 K range, but that is based on the 3930K. OK, my case is extremely expensive, so that increases my costs significantly, but still...
    Jul 23, 2012 1:47 PM   in reply to taunouibo
    The Dual Xeon 8 Core cpu's give you a far higher performance ceiling than the single 6 Core systems. That means you can handle far more layers/cameras with effects with the Dual Xeon system versus the Workstation. That is the main difference in selecting between the 2. Your workflow and editing format essentially decides which one will best suit your needs. Both will handle those codecs fine.
    Eric
    ADK
    Aug 2, 2012 1:18 AM   in reply to taunouibo
    Looks very good, but I would suggest you look at an extra Constellation ES disk as a hot-spare, that gives you more security against disk failure. Have you foreseen in the use of hot-swappable drive cages for the Constellations, like I have in my new system?
    Which SSD do you have in mind? For me, this is the sequence I would look at: Corsair Performance Pro, Samsung 830, Crucial M4, Intel 520, ... , and at the end of the list Corsair Force and OCZ.
