I am working with Rollover Slidelets in Captivate 6 and I can't find a way to hide/remove the "X" button in top right corner of a slidelet.
I believe this is possible because there is no "x" in my previous project. I've compared settings and still couldn't find the difference responsible for it.
What am I missing?
It is a bit difficult when I cannot reproduce your problem on my PC. Are you on PC or Mac? Could you try creating a rollover slidelet in a blank project to see if this is a consistent behavior or just happening in that project? Perhaps you already tried that, in that case I apologize,
Lilybiri
Do you mind losing customization, because if not, would suggest to delete the Preferences folder while Captivate is closed. Maybe something has corrupted there. This folder is labeled 'Captivate 6.0' and can be found in your profile:
C:\Users\<your username>\AppData\Local\Adobe
Beware: it is a system folder, perhaps it is hidden (default) and you'll have to adapt Explorer settings
Lilybiri
Deleting Preferences didn't help.
1. When I create a blank project and insert Rollover Slidelet - it works (x is hidden).
2. When I copy my slide to blank project, remove Rollover Slidelets and insert new ones - it works.
3. When I copy a working slide back to my project - it doesn't work (x is still visible).
4. When I remove Rollover Slidelets in my current project and insert new ones - it doesn't work.
So it looks like my project is somehow corrupted. Any way of resolving this issue?
Yes, that seems to be the case. And not easy to find the 'culprit'
Try this: create a new blank project with the same resolution, copy/paste slides by small bunches and test regularly if everything is OK. Do not paste the slides with rollover slidelets, try to recreate them (perhaps use the Library with assets from the original project as External Library).
Lilybiri
So I copied all slides to a new project and added new slidelets. 6 out of 8 were working. 2 were still showing 'x'. I deleted them and once again inserted new slidelets. Now everything is working fine.
But it's working only when Rollover Slidelets starts with the beginning of a slide (appear after 0 seconds). When I move them a few seconds further into a slide - 'x' button is visible next to all of them.
