Otlas405
How to remove "X" button from Rollover Slidelet?
Aug 2, 2012 12:37 AM
Tags: #x #remove #button #slidelet #rollover #hide
I am working with Rollover Slidelets in Captivate 6 and I can't find a way to hide/remove the "X" button in top right corner of a slidelet.
I believe this is possible because there is no "x" in my previous project. I've compared settings and still couldn't find the difference responsible for it.
What am I missing?
    Aug 2, 2012 1:07 AM   in reply to Otlas405
    Could you check if you have perhaps ticked the option 'Stick slidelet' in the Action accordion of the slidelet? Because that is causing the appearance of the X to close the slidelet:
    Lilybiri
    Aug 2, 2012 1:14 AM   in reply to Otlas405
    That is strange, because I always check before answering, and I do not see that X with the option unticked, as you can see:
    Was this a project created in CP6 or an upgraded one?
    Aug 2, 2012 1:19 AM   in reply to Otlas405
    It is a bit difficult when I cannot reproduce your problem on my PC. Are you on PC or Mac? Could you try creating a rollover slidelet in a blank project to see if this is a consistent behavior or just happening in that project? Perhaps you already tried that, in that case I apologize,
    Lilybiri
    Aug 2, 2012 1:30 AM   in reply to Otlas405
    Upgraded projects can show some weird issues at times.
    Try removing the slidelet and reinserting a new one from Cp6 to see if it behaves differently.
    Aug 2, 2012 1:40 AM   in reply to Otlas405
    Do you mind losing customization, because if not, would suggest to delete the Preferences folder while Captivate is closed. Maybe something has corrupted there. This folder is labeled 'Captivate 6.0' and can be found in your profile:
    C:\Users\<your username>\AppData\Local\Adobe
    Beware: it is a system folder, perhaps it is hidden (default) and you'll have to adapt Explorer settings
    Lilybiri
    Aug 2, 2012 1:58 AM   in reply to Otlas405
    Yes, that seems to be the case. And not easy to find the 'culprit'
    Try this: create a new blank project with the same resolution, copy/paste slides by small bunches and test regularly if everything is OK. Do not paste the slides with rollover slidelets, try to recreate them (perhaps use the Library with assets from the original project as External Library).
    Lilybiri
    Nov 5, 2012 6:26 AM   in reply to Otlas405
    Is Adobe planning to release a fix for this issue?  I have a project with 6 rollover slidelets on one slide, none appear at the beginning of the slide and I have the same issue, X doesn't appear if the slidelet starts at 0, but does if it appears after 0.
    May 15, 2013 12:55 PM   in reply to BethCollins2011
    I am having this same issue whene the rollover slidelets are not at the beginning of the slide. Any word on if this is being worked on?
