Adding detail to html data set table
Jul 24, 2012 1:12 PM
I have created a table with an html dataset to display class schedules:
http://www.units.muohio.edu/lifelonglearning/ilr/fall2012working.html
Source dataset:
http://www.units.muohio.edu/lifelonglearning/ilr/fall2012-dataset.html
Is there a way to add a link so that when {course} is selected {description} is displayed?
    Jul 24, 2012 9:32 PM   in reply to BerlyMeister
    One way to do this is to have a window pop-up when clicking on the course.
    1.For the repeat region add spry:setrow ="ds1fall2012ilr" as in
    <tr spry:repeat="ds1fall2012ilr" spry:setrow="ds1fall2012ilr" spry:odd="odd" spry:even="even" spry:hover="hover" spry:select="select">
    2. Create a spry detail-region after the spry region as in
      </table>
    </div>
    <div id="apDiv1" spry:detailregion="ds1fall2012ilr">
      <div>{Description}</div>
      <div><input name="" value="close" type="button" onclick="MM_showHideLayers('apDiv1','','hide')" /></div>
    </div>
    I have added an ID to the detail-region, placed the description and a button with an onclick event.
    3. Now we need a few style rules for our detail-region as per
    #apDiv1 {
        position: absolute;
        left: 122px;
        top: 1400px;
        width: 761px;
        height: 341px;
        z-index: 1;
        background: #CCC;
        visibility: hidden;
        padding: 20px;
    This will absolutely position the detail-region and hide it to start with.
    4. When we click on the course we want the detail-region to show as in
    <td onfocus="MM_showHideLayers('apDiv1','','show')">{Course}</td>
    5. And lastly, a bit of JS that will handle our events
    function MM_showHideLayers() { //v9.0
      var i,p,v,obj,args=MM_showHideLayers.arguments;
      for (i=0; i<(args.length-2); i+=3)
      with (document) if (getElementById && ((obj=getElementById(args[i]))!=null)) { v=args[i+2];
        if (obj.style) { obj=obj.style; v=(v=='show')?'visible':(v=='hide')?'hidden':v; }
        obj.visibility=v; }
    All of the above has been done using DW. The apDiv1 was drawn using Draw AP Div feature. The onclick events and JS were done in the Behaviours panel.
    This is a very crude model of what can be done. You might like to have a look at http://linecraft.com/spry-pop-up-dialog/extension.php for a proper pop-up or use one of the light boxes. The example is only limited by your imagination.
    Gramps
    Jul 25, 2012 6:21 AM   in reply to BerlyMeister
    A couple of additions/changes need to be made; some of the changes are as a result of my hastily made errors.
    1. Underneath line #8 add the following highlighted
    <style type="text/css">
    .style8 {color: #EEEEEE}
    #apDiv1 {
        position: absolute;
        left: 122px;
        top: 600px;
        width: 761px;
        height: 341px;
        z-index: 1;
        background: #CCC;
        visibility: hidden;
        padding: 20px;
    </style>
    2. In line #125 change onfocus to onclick as in
    <tr spry:repeat="ds1fall2012ilr" spry:setrow="ds1fall2012ilr" spry:odd="odd" spry:even="even" spry:hover="datahover" spry:select="dataselect">
      <td>{Day}</td>
      <td>{Time}</td>
      <td>{Weeks}</td>
      <td>{Begins}</td>
      <td onclick="MM_showHideLayers('apDiv1','','show')">{Course}</td>
      <td>{Oxford}</td>
      <td>{Fairfield}</td>
      <td>{Hamilton}</td>
      <td>{West_Chester}</td>
      <td>{Other}</td>
    </tr>
    That should do it.
    Gramps
    Jul 25, 2012 11:13 AM   in reply to BerlyMeister
    Place the cursor on line #122 of your document, then add the Spry Pop-up Dialog. You may get a warning issued by DW which you can ignore.
    What this has done is
    1. inserted links to the JS and CSS files in the head section of the document
    2. placed a constructor for the pop-up near the bottom of the document
    3. created the markup for the pop-up
    4. created a clickable link to activate the pop-up
    All we need to do now is to
    1. change the pop-up to suit us as per
    <div id="spryPopupDialog1" class="popupContainer" spry:detailregion="ds1fall2012ilr">
      <div class="popupBox">
        <div align="right" class="popupBar"> <a class="popupClose" href="javascript:;" onclick="spryPopupDialog1.displayPopupDialog(false);">-</a>
          <div class="popupTitle">POPUP DIALOG TITLE</div>
        </div>
        <div class="popupContent">{Description}</div>
      </div>
    </div>
    2. cut the link on line #122 and place it in the table cell as per
    <td><a href="javascript:;" onclick="spryPopupDialog1.displayPopupDialog(true);">{Course}</a></td>
    you will have noticed that the onclick event that we put there originally, has been removed
    3. remove other remnants of the detail region as in
    </div>
    and
        obj.visibility=v; }
    These are no longer needed.
    4. test the page in your favourite browser.
    Gramps
    Jul 25, 2012 5:27 PM   in reply to BerlyMeister
    Remove the useEffect and it will work
    var spryPopupDialog1 = new Spry.Widget.PopupDialog("spryPopupDialog1", {allowDrag:true, allowScroll:true, useEffect:"fade", modal:true});
    Get in touch with Alex July and he will fix it for you, great guy.
    Gramps
    Jul 26, 2012 5:38 PM   in reply to BerlyMeister
    Thank you for your feedback, I shall certainly keep this in mind.
    Have a look at his other products, like the Spry Utilities extension http://www.linecraft.com/, and service bar none!
    Gramps
    Jul 31, 2012 7:00 PM   in reply to BerlyMeister
    This is the error message
    SCRIPT5007: Unable to get value of the property 'filter': object is null or undefined
    SpryPopupDialog.js, line 447 character 3
    and this is the affected script
    if (Spry.is.ie)
      var filter = this.popupBox.currentStyle.filter.replace(/alpha\s*\(\s*opacity\s*=\s *[0-9\.]{1,3}\)/, '');
      this.popupBox.style.filter = filter+"alpha(opacity=" + parseInt(ht * 100, 10) + ")";
    It looks like friend Alex needs to be involved.
    Gramps
    Aug 2, 2012 6:11 AM   in reply to BerlyMeister
    As the saying goes, 'you are never too old to learn'.
    Thank you for sharing.
    Gramps
