crisadi96
System hiccups
Aug 2, 2012 3:37 AM
Tags: #problem #cs5 #help #hardware #premiere_pro #export #pc
Greetings everyone, and my most sincere apologies should this topic exist somewhere else.
I own a workstation-class computer, specifications are as follows:
Asus P9X79 (Not PRO)
Intel Core i7 3930-K (standard clock)
SSD Corsair ForceGT 120GB SATA3 for Operating System
2x Dual Channel 4x Corsair Vengeance LP DDR3 16GB 1600 CL9 kits (32GB in total)
2x HDD Hitachi 1TB 7200RPM 32MB SATA3 (linked through RAID 0)
Noctua NH-D14
Asus GTX570 DirectCUII 1.28GB (standard clock)
OCZ 750w Power Supply (bronze certificate)
Zalman Z9 case
The problem lies in the fact that, every time I am working on Premiere Pro CS5 (1920x1080i AVCHD from my AG-AC160, as well as DV 720x576) the computer simply freezes randomly when working on the projects. In addition, the HDD activity LED lights up until the system is manually restarted. It is severely frustrating, but I have high hopes that the topic will provide answers to this mystery.
In case you were wondering, encoding times when making the DVD using Encore are 75% of the DVD's time, and for BluRay it is 100+, that is, if I am not using visual plugins for color grading, which would increase export times tenfold.
Looking forward to answers soon!
    Aug 2, 2012 3:45 AM   in reply to crisadi96
    Can you attach links to your DXDIAG results and Piriform Speccy .XML results and show screenshots from Process Explorer?
    Aug 2, 2012 4:07 AM   in reply to crisadi96
    Are you using the latest BIOS for your motherboard?
    What you are experiencing sounds just like my problems when I first built my 3930K system.  You must use a BIOS released after April to eliminate these random freezes.  The problem is related to memory (in)compatibility with the 3930K processor.
    Aug 2, 2012 4:56 AM   in reply to crisadi96
    Thanks for the screenshots, but I meant the complete .txt and .xml files. The screenshots do not really help, apart from Process Explorer.
    Aug 2, 2012 6:32 AM   in reply to crisadi96
    Here is an example of a Speccy.xml file
    The HTML code is: <a href="www.domain_name.domain_extension/directory/filename" target="new">Description</a>
    target="new" causes the link to display in a new tab. You can leave that out if you want, but personally I prefer that addition.
    Aug 2, 2012 6:57 AM   in reply to crisadi96
    Thanks for the info. Very helpful.
    1. Update your video driver. You are running 296.10 and should be running 301.24 or 304.79
    2. What are you using the Samsung display for? With a resolution of 1360 x 768 it is not suited for PR work.
    3. Your disk setup should not cause problems, unless one of your raid0 arrays is getting finicky.
    4. Check your event viewer for possible raid problems and run CHKDSK at boot time to make sure the arrays are OK.
    I hope the BIOS update was all that was needed.
    Aug 2, 2012 7:10 AM   in reply to crisadi96
    Glad the BIOS update worked for you!
    Aug 2, 2012 12:14 PM   in reply to crisadi96
    As Harm said the 768 pixel vertical resolution is not suitable for working with the Premiere GUI and could cause usability problems.  The minimum Premiere primary screen resoultion is 1280 x 900..
