Textfield and eventlisteners
Aug 2, 2012 4:57 AM
Hi guys, i fee im plauging this forum sometimes, this code lets a user input text and click a button which outputs it to a textfieldand also adds a number to another textfield. Another button removes this text and also subtracts the same number. It all works fine when there is text in the input field but when it is empty and you click the button that adds the text it still adds to the number.
[AS]
var textAdd01 : Number;
          textAdd01 = 3;
LBtextMenu.LBtxtSubmit.addEventListener(MouseEvent.MOUSE_UP, LBtypedChar);
function LBtypedChar(evt:MouseEvent):void
LBTxt.LBOutput.text = LBtextMenu.LBInput.text;
LBtextHotspot.gotoAndStop(2);
trace (LBTxt.LBOutput.text.length)
///----------------------Add Price---------------------------------------
LBtextMenu.LBtxtSubmit.addEventListener(MouseEvent.MOUSE_UP, LBtxtAddPrice);
function LBtxtAddPrice(evt:MouseEvent):void
priceOutput.text = String(textAdd01 + Number(priceOutput.text));
if (LBTxt.LBOutput.text.length >0){
          LBtextMenu.LBtxtSubmit.removeEventListener(MouseEvent.MOUSE_UP, LBtxtAddPrice);
          LBtextMenu.LBtxtRemove.addEventListener(MouseEvent.MOUSE_UP, LBtxtRemovePrice);
LBtextMenu.LBtxtRemove.addEventListener(MouseEvent.MOUSE_UP,LBtxtRemov eTxt);
function LBtxtRemoveTxt(e:MouseEvent)
  LBTxt.LBOutput.text = "";
          LBtextHotspot.gotoAndStop(1);
///----------------------Remove Price---------------------------------------
function LBtxtRemovePrice(evt:MouseEvent):void
priceOutput.text = String(Number(priceOutput.text) - textAdd01);
if (LBTxt.LBOutput.text.length ==0){
          LBtextMenu.LBtxtRemove.removeEventListener(MouseEvent.MOUSE_UP, LBtxtRemovePrice);
[/AS]
Thanks for any help in advance.
    Aug 2, 2012 5:07 AM   in reply to TwistedPixel23
    It is difficult to tell what's what, but for the code you show I can see where you do check the length value of some text.  That is what you should be doing to control whether or not actions are taken.
    For instance...  if the following function is involved with your problem, then you should test the length of the text to decide if you want to process it or not....
      if(LBtextMenu.LBInput.length > 0){
          trace (LBTxt.LBOutput.length);
    Note that in that code the way the length is checked is a tad shorter.  The textfield itself has a length property that reflects the same value as the length property of the String inside it.
    Aug 2, 2012 6:26 AM   in reply to TwistedPixel23
    Did you not follow what I suggest you do to control when code executes or not?  I didn't mention anything regarding traces.
    Aug 2, 2012 6:52 AM   in reply to TwistedPixel23
    An event listener will still work as long as it is active, it is what the event handlers function does that means anything.
    You need to show what you did.  I was just providing an example of what you should do.  You probably need to find the correct place(s) to inject that kind of conditional processing.
    Aug 2, 2012 7:41 AM   in reply to TwistedPixel23
    You're welcome
