Separate CSS for IE and Firefox
Aug 2, 2012 7:05 AM
Hi all,
older versions of Robohelp generated to separate CSS files in the Wephelp for IE and Firefox. Evidently this feature was dropped somewhen. However I need it now to resolve some specific Firefox problems in a project.
I thought I could add the corrsponding script in the master page that checks for the browser and selects the CSS, but thought I should ask the forum first.. are any solutions for this already known?
Robert
    Aug 2, 2012 7:27 AM   in reply to robert-sfl
    I think it was RoboHelp 7 where things changed, may even be 6, but since then one CSS should work in all browsers.
    Maybe the better starting point is what are the issues between the two browsers that are affecting your output.
    @petergrainge
    Aug 2, 2012 8:50 AM   in reply to robert-sfl
    If you are sure there is no way around OK but sometimes someone knows a solution. I'm not saying I do, just that sometimes someone will pop their head over the parapet with the answer.
    It used to be the case that bullets were a pain for me until I found out that Firefox's own CSS had an indent that you could negate without affecting IE. Result, almost the same appearance in both browsers.
    I haven't tried it but RoboHelp 10 allows you to write media queries and you can define the browswer. In theory you can have a default style for IE and other browsers but specify a rule that if the browser is Mozilla, the CSS is to be modified.
    That's the cheery theory and I don't know the ins and outs of how well it would work in reality. Do let us know if you decide to take the plunge.
    @petergrainge
    Aug 3, 2012 1:58 AM   in reply to robert-sfl
    This was changed in RH8. If you want to target IE in your css only, you will need a css hack (not recommended!). It would be best to identify the problems and remake the CSS so that you can support all browsers. Normally, all browsers are correct, instead of IE. So instead of fixing FF, you are fixing IE L
    Take a look at the following link:  <http://dimox.net/personal-css-hacks-for-ie6-ie7-ie8/> http://dimox.net/personal-css-hacks-for-ie6-ie7-ie8/
    Greet,
    Willam
