Build Maven KO
Jan 19, 2011 8:14 AM
Salut,
J'ai le message d'erreur suivant après récupération du trunk ou de la release 1.2:
> maven package
[ERROR] Failed to execute goal on project flex-pmd-flex-lib: Could not resolve dependencies for project com.adobe.ac:flex-pmd-flex-lib:swc:1.3-SNAPSHOT: Failed to collect dependencies for [com.adobe.ac:flex-pmd-ruleset:jar:1.3-SNAPSHOT (compile), com.adobe.cairngorm:event-source:swc:1.1 (test), com.adobe.cairngorm:cairngorm:swc:2.2.1 (compile), com.adobe.flex.framework:flex-framework:pom:3.2.0.3958 (compile), com.adobe.flex.framework:playerglobal:swc:10-3.2.0.3958 (compile), com.adobe.flex.framework:datavisualization:swc:3.2.0.3958 (compile), com.adobe.flex.framework:datavisualization:rb.swc:en_US:3.2.0.3958 (compile), org.sonatype.flexmojos:flexmojos-unittest-support:swc:3.5.0 (test), junit:junit:jar:4.7 (test)]: Failed to read artifact descriptor for com.adobe.cairngorm:event-source:swc:1.1: Could not transfer artifact com.adobe.cairngorm:event-source:pom:1.1 from/to apache (http://cvs.apache.org/repository/): No connector available to access repository apache (http://cvs.apache.org/repository/) of type legacy using the available factories WagonRepositoryConnectorFactory
Quelqu'un a une idée?
Merci!
MAB
Qualixo (FR)
    Aug 1, 2012 12:08 PM   in reply to MABqualixo
    I am cross referencing a similar thread that about this same issue: http://forums.adobe.com/thread/1041494
    It started when I tried to build FlexPMD with Maven 3.x, then I downgraded to Maven 2.x in order to access the 'legacy' repos.  However with Maven 2.x I arrived at the same place where Qualixo arrived, so presently I am still unable to build FlexPMD until this is resolved.
    Aug 2, 2012 8:02 AM   in reply to Steven Erat
    To anyone finding this thread with a Maven 2 build error matching the above, see the previous cross referenced link.  The solution is to build from flex-pmd-java-parent intead of flex-pmd-parent.
