Hello,
I'm currently working on a project and my client want it in 5 different formats (Blu-ray, DVD, tablet, mobile phone and internet-flv).
Exporting 5 times the timeline is very time consuming so I want to do it once and convert this master with TMPGenc 5 to all needed formats.
I want some advice how to export from Premiere CS6.
The footage from my camcorders is AVCHD 1920x1080 and pal-interlaced and the output must also be interlaced.
When exporting from Premiere, I got 4 UT options:
RGB
RGBA
YUV420
YUV422
Which one fits best to my source footage or is the best for TMPGenc?
When I set Field order to Upper First, must I also checked "Assume interlaced video" on the Codec Settings box? I did already some tests but when I import some exported file to TMPGenc, it always says it's a progressive file.
I've also tests RGB vs YUV420 but the RGB file is much bigger (2x) and I'm asking myself if this is worth because of my source footage.
Hope someone could help me in the right direction.
Thanks Jim!
I know the Media Encoder could do all the encoding but exporting my timeline with many effects once to h264 will take around 4-5 hours from direct export. With Media Encoder much longer.
Have to do this 3 times with different profiles/bitrates and for DVD, I'm mostly using TMPGenc with frameserver but in this case I use the UT exported file.
TMPGenc with x264 gives also better results at low bitrates wich is good voor portable devices.
Well, I'd agree that x264 is the way to go.
But for clarity, I wasn't just saying that AME can do all the encoding. It's always been able to do that. I was saying that with CS6, AME can do all of the encoding at the same time. Used to be that if you wanted several versions of an export, AME would go through each one in sequence, but now it can do them all at once.
