Odd James
PSE 10 Liquify filter
Aug 2, 2012 10:42 AM
Can not view image at full size when in liquify.  e.g. the image is much smaller when you select liquify and when you enlarge it it pixelates.  Is there a adjust or is something wrong with my Elements?
    Aug 2, 2012 11:04 AM   in reply to Odd James
    I have PSEv.8.
    In the Liquify filter dialog, select the manifying glass icon on the left at the bottom, above the hand tool.
    Left click to enlarge, ALT+click to make smaller
    Aug 2, 2012 1:35 PM   in reply to Odd James
    The problem is that elements uses a modified version of liquify from the photoshop 7 era (2002 or there abouts) (on the windows versions, it may be the same on mac versions as well)
    and that version didn't show zooming in actual pixels either.
    That would be an excellent feature request that you could post over here:
    http://feedback.photoshop.com/photoshop_family/topics
    Aug 2, 2012 2:28 PM   in reply to R_Kelly
    On my PSE10, the Liquify filter's zoom function works perfectly well.
    Ken
    Aug 2, 2012 3:44 PM   in reply to photodrawken
    The zoom function works, but is not zooming the actual image pixel for pixel, but i believe uses a low resolution preview of the image.
    You can see the difference Odd James is talking about by comparing the way the Correct Camera Distortion filter works versus the Liquify filter.
    (the default photoshop elements versions of those filters)
    Aug 2, 2012 5:03 PM   in reply to R_Kelly
    I'm not sure, but there is probably an upper limit to the size of file that Liquify can handle, everything above that get's proxied.
    How large are these files that you are working with? I just tested with a couple decent sized file (certainly not the largest I have on hand, but they included grids so it was easy to compare) and the size is the same.
    Aug 2, 2012 5:38 PM   in reply to Brett N
    Yes it's most noticable on files such as camera raw files with larger pixel dimensions.
    If you take a file of say 6144 pixels x 4085 pixels and open in the liquify filter, you see the zooming is clearly not showing the actual image
    size in relation to the zoom percent shown at the bottom left of the pse liquify dialog.
    100% view in the pse liquify filter is not the same 100% view in the editor. (actual pixels).
    That is cetainly a built limitation of the version 7 liquify on which i believe the pse version of liquify is based, but more recent versions of the
    liquify in photoshop from cs up showed the actual size of the image inside the liquify dialog without the pixelated look one gets in the pse version.
    Oct 18, 2012 11:56 PM   in reply to Odd James
    In case your interested, in photoshop elements 11 the liquify issue seems to have been fixed.
    That is pse 11 shows the fullsize image in Liquify.
