Amm85
How to display query result like this
Aug 2, 2012 1:14 PM
I got a query...gives list of names.
i want to display
11.  Peter
12. Jessica
32. Leo
15. Jamie
36. Edward
how i get static number infront of my query result.
static number is not in order.
    Aug 2, 2012 2:33 PM   in reply to Amm85
    From where do these numbers come?
    Aug 2, 2012 7:04 PM   in reply to Amm85
    Is there any correlation between the number and name?
    Aug 3, 2012 8:19 AM   in reply to Amm85
    #QueryName.CurrentRow# ????
    Aug 3, 2012 9:54 AM   in reply to Amm85
    i want to display
    11.  Peter
    12. Jessica
    32. Leo
    15. Jamie
    36. Edward
    You could use the function queryAddColumn to add the numbers as a separate column to the query.
    Let us suppose the name of the query is "myQuery". Then you could proceed as follows
    <!---Define your "static" list of numbers --->
    <cfset staticList = "11,12,32,15,36,13,23,14,33,16,44,31,17,34,18">
    <!--- Create an array from the static list. --->
    <cfset staticNrArray = ArrayNew(1)>
    <cfset staticNrArray = listToArray(staticList)>
    <!--- Add the array as a column to the query. --->
    <cfset nColumnNumber = QueryAddColumn(myQuery, "staticNr", "integer", staticNrArray)>
    <!--- Verify whether it works as expected--->
    <cfdump var="#myQuery#">
    The list I have given here has 15 numbers. This will naturally instruct ColdFusion to add a new column named staticNr, having 15 rows. You might like to know that the queryAddColumn function enables padding.
    Here is how it works. Suppose that the query originally had only 8 rows before you added the column(of 15 rows). Then, in the new query, ColdFusion would pad the last 7 rows of the other columns with null values. If the original query  had 20 rows instead, then Coldfusion would pad the last 5 rows corresponding to the staticNr-column with null values.
