When i work on flash file to export a swf file in order to use it in ADWORDS, but i always decreasing the images in the swf to get the required size for ADWORDS 50 k.
I need some suggestions or tips & tricks to get an swf with 50 k size without decreasing imges resolutions
A Flash swf file will carry whatever weight you put into it. So if you want to keep it below 50k you need to fill it with less than 50k of content. The only ways to keep the contributions of image files low is to either keep the number of them low, and/or keep the physical dimensions of the low, and/or optimize them, and/or dynamically add the weight/files (likely not an option).
Here's a web article that may be useful: http://www.sitepoint.com/steps-faster-flash/
If you are strictly concerned about bitmap images like photos, then Photoshop's Save for Web tool is very useful. You can test your images in various file formats and at various color depths to get the smallest possible file with the best possible quality. If you are working with vector graphics, then use simple shapes and flat color.
If you show us an example of the art that you're working with, someone might be able to give you more specific and useful information.
I have also found that after the file is finalized and ready to be published that within the "library" panel in the top right corner is the little icon that has the three bars on it. upon opening this panel there is an option towards the bottom that allows you to select any and all unused assets from the file. sometimes when building the files you might have extra assets that are no longer being utilized within the movie or perhaps you brought in a trace image. selecting this will remove the extra baggae. after this re-pblish the file and the size hopefully will drop some.
GL
Russ
Be EXTREMELY careful when deleting Library assets! If you have an object in the Library that is linked to be used by actionscript but is never actually shown in the Timeline, that object will be deleted by that command.
Also remember that the size of the .fla has no bearing on the size of the .swf. You should keep a neat and tidy Library, but be very careful about what you delete.
