Eric1676
Need Horizontal Spry Menu Bar to Left Justify
Aug 2, 2012 1:54 PM
I'm using DW CS6.  Horizontal Spry Menu Bar is in a fluid grid layout div tag.
The horizontal menu bar floated left until I made a CSS change (I think).  It now floats right and I can't figure out how to get it back to float left.  Does anyone know a fix?
Spry Menu CSS is:
ul.MenuBarHorizontal
           margin: 0;
           padding: 0;
          list-style-type: none;
          font-size: 100%;
          cursor: default;
          width: auto;
and fluid grid layout CSS for div is
#menuHorizontal {
          clear: both;
          float: left;
          margin-left: 0;
          display: block;
The page in progress is at http://www.bedroomandmore.com/1_b_fluidGrid.html
Thanks Much!
    Aug 2, 2012 2:05 PM   in reply to Eric1676
    Hi Eric,
    You might want to validate your page first:
    http://validator.w3.org/
    There are quite a few errors and correcting those will make it much
    easier for someone to help you.
    Al Sparber - PVII
    http://www.projectseven.com
    The Finest Dreamweaver Menus | Galleries | Widgets
    Since 1998
    Aug 2, 2012 5:03 PM   in reply to Eric1676
    You have an element sitting in the way . In my opinion, the Adobe fluid grid "system" is very poorly thought out. It seems to have been cribbed from various popular articles on responsive design, which my company reviewed and deemed a bit ridiculous. This is all you need to do to make a responsive layout:
    http://www.projectseven.com/products/staging/adaptations/
    And it has the added benefit of actually displaying in a readable text-size on smartphones. The above page is a prototype for an upcoming product, but feel free to browse the code and learn from it.
    The CSS for your page, on the other hand, is way over the top and falling into the abyss. Perhaps someone with more patience and who sees redeeming value in the Adobe grid can help you. My advice would be to ditch it.
    I would also add that if you want a truly responsive and usable layout that your horizontal menu should change, at the smallest breakpoints, to a vertical display with each root link spanning its container.
    Aug 2, 2012 6:01 PM   in reply to Eric1676
    Just a note - if you assign the wrapper you have placed around the menu
    a negative left margin, it will pull over. However, your address stuff
    is in the way. Responsive layouts are easy. Adobe's is simply not good -
    in my opinion. But if you like it, you are certainly entitled to your
    own opinion. I would test your page quite thoroughly in all browsers
    using real browsers instead of BrowserLab and I would also test iPad and
    iPhone and perhaps Androids before signing off on that page
    Good luck!
    Al Sparber - PVII
    Since 1998
