I got a query...gives list of names.
i want to display
11. Peter
12. Jessica
32. Leo
15. Jamie
36. Edward
how i get static number infront of my query result.
static number is not in order.
i want to display
11. Peter
12. Jessica
32. Leo
15. Jamie
36. Edward
You could use the function queryAddColumn to add the numbers as a separate column to the query.
Let us suppose the name of the query is "myQuery". Then you could proceed as follows
<!---Define your "static" list of numbers --->
<cfset staticList = "11,12,32,15,36,13,23,14,33,16,44,31,17,34,18">
<!--- Create an array from the static list. --->
<cfset staticNrArray = ArrayNew(1)>
<cfset staticNrArray = listToArray(staticList)>
<!--- Add the array as a column to the query. --->
<cfset nColumnNumber = QueryAddColumn(myQuery, "staticNr", "integer", staticNrArray)>
<!--- Verify whether it works as expected--->
<cfdump var="#myQuery#">
The list I have given here has 15 numbers. This will naturally instruct ColdFusion to add a new column named staticNr, having 15 rows. You might like to know that the queryAddColumn function enables padding.
Here is how it works. Suppose that the query originally had only 8 rows before you added the column(of 15 rows). Then, in the new query, ColdFusion would pad the last 7 rows of the other columns with null values. If the original query had 20 rows instead, then Coldfusion would pad the last 5 rows corresponding to the staticNr-column with null values.
