lariviere5247@rogers.com
have downloaded camera raw update 7.1, but have had no luck installing it.
Aug 2, 2012 8:22 PM
I know that I've done this before....and had some difficulty with it at times...but this it's got me beat.
thanks
    Aug 2, 2012 10:36 PM   in reply to lariviere5247@rogers.com
    And for which program are you trying to update ACR? On which platform? You need to bve more specific.
    Mylenium
    Aug 3, 2012 2:22 AM   in reply to lariviere5247@rogers.com
    lariviere5247@rogers.com wrote:
    I'm not sure how to unzip it ...
    If the file has a .zip extension (or other compressed archive file extension), you just open it with WinZip, then extract the contents.  Most likely there is some .exe file which you can run to install the update.  You may even be able to run it from inside WinZip.
    Aug 3, 2012 9:17 AM   in reply to lariviere5247@rogers.com
    Camera Raw 7.1 will not work in Photoshop CS5. The last version of Camera Raw for CS5 is ACR 6.7.
    Aug 3, 2012 12:00 PM   in reply to lariviere5247@rogers.com
    The latest update for  CS5 is ACR 6.7. If the camera you own is not supported in that version, you can download and install the free DNG converter. Convert your files to DNG and you will be able to work with your images in CS5. http://www.adobe.com/support/downloads/detail.jsp?ftpID=5388&promoid=D TEHQ
  • Noel Carboni
    Dec 23, 2006
    Aug 4, 2012 2:10 PM   in reply to Pat Willener
    Windows will open a zip file without any need for a 3rd party application like WinZip.  You need just "Open" the file.
    -Noel
