LesToil
Using shift key to extend line or paint stroke
Aug 2, 2012 10:58 PM
Hello all. I've been using a very old version of Photoshop for the last 10 years and I'm used to using the shift key to extend a line or paint stroke. By that I mean,  I use the paint tool to make a dot and then hold down the shift key and make another dot elsewhere and that creates a straight line. I just purchased CS6 and that function doesn't  seem to be happening. Is this something I need to activate in a preference?
Thanks very much for any and all help.
    Aug 2, 2012 11:05 PM   in reply to LesToil
    The function still applies but you may have chosen a Brush Preset with a Pressure sensitive Shape Dynamics (or other) property.
    Could you please post a screenshot with the pertinent Panels visible?
    Aug 3, 2012 12:05 AM   in reply to LesToil
    What are the Transfer settings? Any pressure or fade?
    Aug 3, 2012 1:07 AM   in reply to LesToil
    Which Tool do you use and what is checked in the Options Bar (»Always use pressure for size …« for example)?
  • Noel Carboni
    Dec 23, 2006
    Aug 3, 2012 11:00 AM   in reply to LesToil
    There's something strange going on here...
    Like you, I have always relied on Shift giving me straight strokes from last point to current point.  However, I just tried it with the setting both ways and in both cases it worked.
    Click this to see an animation...
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Aug 4, 2012 11:11 AM   in reply to LesToil
    I don't have a tablet, so pressure sensitivity makes no sense for me.   I assume you have one, which may explain the difference in operation.
    I use IrfanView, set to capture the display every 5 seconds and save the results in a PNG file, then methodically work through examples.  When done, I load all the saved images into a stack and make a frame animation in Photoshop.  It's not too difficult once gone through a few times.  Most folks might suggest getting a desktop video recording tool, though, like Camtasia or Captivator.  With a video you get smoother motion and you can narrate.
    -Noel
    Aug 4, 2012 11:50 AM   in reply to LesToil
    It works here on windows 8 using a wacom tablet with cs6, even with the override buttons enabled.
    Have you updated the tablet driver to the latest version?
