Raja1205
How to identify "non-image" object compressed or not in a PDF file
Aug 3, 2012 1:17 AM
I wanted to upgrade the PDF version from "1.4/1.5" to "1.6" using "Acrobat X pro" as mentioned in the screenshot but unfortunately "non-image objects" also compressed when upgrading the PDF.
Screenshot for PDF upgradtion:
So kindly advise any one of the following:
1. How to Upgrade PDF version without "non-image" objects compression?
2. How to identify "non-image" objects compression was applied or not" in a PDF file.
Thanks in advance for your help and support.
Raja. S
    Aug 3, 2012 4:53 AM   in reply to Raja1205
    Please see the response posted in your other post on the same topic Is it possible to find "non-image objects compression" using preflight in "Acrobat X pro"?.
    Aug 14, 2012 12:41 AM   in reply to Raja1205
    Compressing page streams (which contain text and vector graphics) is nearly always done. There is no way to turn it off in Acrobat, a few older programs may not do this. Preflight isn't likely to report anything so normal.
    What is the real problem you are trying to solve?
    Aug 14, 2012 3:25 AM   in reply to Raja1205
    Because all PDF files can be expected to compress text and line art, I do not think you will find any options in Acrobat to remove or check for this.  (The PDF optimizer will go the other way, compressing page streams which were not compressed).
    Because these requirements are extremely unusual, and because Acrobat has no reason to meet them, I think it is entirely proper for you to ask the client how they are to be achieved. They may use custom software both for conversion and for validation.
    If the client provides a technical specification for their requirements, you might find it worthwhile to post it here, as it may give more insights into the problem they are trying to avoid.
    Aug 24, 2012 5:18 AM   in reply to Raja1205
    Ah, now I understand the confusion. The issue relates to "compressed object streams". These are nothing to do with whether things are images or non-images, but are part of the internal format of the PDF.
    You have full control over this in the PDF optimizer under the "Clean up" tab.  They are described as "Object compression options". To fulfil this preflight rule, choose Remove compression. Confusingly, this will have no effect on image compression or text or line art compression.
    Perhaps the best thing for the profile is if you ask your contact to export a copy of their preflight profile. There are export and import buttons available when going into Edit on the profile.
