Tsar_King
Dreamweaver CS6 Creating a Template (page_content)
Aug 3, 2012 6:05 AM
Tags: #template #dreamweaver #css #insert #cs6 #objects #editable #region #page_content
Hello, i am working through a book called "against the clock dreamweaver cs5" . I am assuming that because the new cs6 is different from the old version ; the two versions might be different. Anyways , I made a CSS layout and went to (Insert> Template Objects> Editable Region)
the book says," In the New Editable Region dialog box, type "page_content" in the Name field and click ok.
Place the insertion point in the table cell that contains the editable region. In the Properties Panel. change the vertical alignment of the cell to Top.
When I go to the Properties Panel, there is not drop-down menu that say Vert > Top.
Please help ASAP!!!
    Aug 3, 2012 6:25 AM   in reply to Tsar_King
    You have to click in a cell in the table.  When you do that the *BOTTOM* half of the expanded Property inspector (to expand it you would click on a little white, 'flippy' triangle in the bottom, right-hand corner of the unexpanded Property inspector).  On expanding you will see two alignment lists appear, one for Horiz and one for Vert.  You can take it from there.
    Aug 3, 2012 6:26 AM   in reply to MurraySummers
    And by the way, this has nothing to do with templates.  I would ask that you change the subject line to a more descriptive one next time.  This one should be something like "setting vertical alignment in table cells", no?
