Importing PDF Files to Framemaker
Aug 2, 2012 11:45 PM
Tags: #import #fm10
Hi all,
I have a query. How do I import a PDF file to a FM File. The PDF files are years old and we dont have the source file now. To update the files, Im trying to
retrieve the source files. I did try the File -> Import -> File, Select the document, select the Copy Into Document option and import option.  The document is imported as reference and not an editable file.
Can someone help me with a solution.
    Aug 3, 2012 5:24 AM   in reply to Swaminathan MRMWRITES
    Right. That's how that works.
    Unless the PDF has paranoid security (and you will have lost the passwords with the source, in all likelihood),
    • you can use Acrobat Reader's Tools > Basic > Select to grab the raw text, and
    • you can use Adobe Illustrator to deconstruct pages and recover images.
    What version of Acrobat Pro do you have, if any? It can re-export PDF content in some WP formats (not MIF or FM, however). Adobe is promoting this feature at the moment:
    http://www.adobe.com/products/acrobatpro/pdf-to-word-excel-converter.h tml?promoid=ITKJK
    Aug 3, 2012 8:22 AM   in reply to Swaminathan MRMWRITES
    In Acrobat X Pro, you can use File> Save As> and then choose Microsoft
    Word or Other Options to retrieve text-- though it will probably need
    some cleanup afterwards. Tools> Document Processing> Export All Images
    can retrieve graphics.
