Hi
I'm pretty new to PS, have used PSE prior to getting the whole CS6 package, so I might ask an obvious question to some.
I have a bunch of pictures, which I want to add 1.0 exposure to and maybe a few other adjustments.
Is there a way to make this automaticly to a bunch of files?
I have been looking at the automate and script menu items, but it is a bid hard for me to see ifvit is possible that way.
Thanks in advance
Ulf
You can record an Action of the task performed on one file, then use "File > Automate > Batch..." to run that Action on folders of files.
http://tv.adobe.com/watch/the-complete-picture-with-julieanne-kost/epi sode-4/
Look at Photoshop's menu File>Automate>Batch and menu File>Scripts>Image Processor... Also if you want to use automation in CS6 and you use a PC not a Mac there is a nasty bug in the PC version of CS6 that cause many Actions and Scripts to fail if you modify your Photoshop's Preferences and Un-Check open document in Tabs. So do not un-check "open Documents in Tabe" in Photoshops Preferences.
Look also into the Image Processor script as well (File - Scripts - Image Processor...). It can run an action, and its user interface may make the process of choosing files to work on and save more straightforward for you (opposed to File - Automate - Batch).
Edit: Oops, I see JJ has already mentioned Image Processor above. I must have skimmed over that before.
-Noel
Thanks Conroy2009 - this video really helped me out - it went just smooth ![]()
Thanks all for your input.
/Ulf
