onOpen is not defined error
Aug 3, 2010 3:27 PM
  I've been using Dreamweaver CS5 since it came out and just today I randomly received the message:  While executing onLoad in _onOpen.htm, the following JavaScript error(s) occurred: In file "_onOpen": onOpen is not defined.  I looked up the issue and it said after awhile some files in Dreamweaver start to crash and that this was a simple fix.  I read that you have to go into folder options and turn on show hidden folders so you can see the folder in which you have to do the file correction.  The folder is located in the documents and settings directory which I cannot seem to find.  I am using Windows 7 and all of the helps I have found are for Dreamweaver 8 and I've tried to look up how to find the documents and settings folder on w7 but I can't seem to find anything.  Any help would be much appreciated on how to solve this issue.
    Aug 3, 2010 3:35 PM   in reply to djones0305
    C:\Users\<you>\AppData\Roaming\Adobe\Dreamweaver CS5\en_US\Configuration
    Aug 3, 2010 3:43 PM   in reply to djones0305
    You find the WinFileCache file and delete it.
    Aug 3, 2010 3:46 PM   in reply to djones0305
    That should have fixed it.  Did it?
    Dec 10, 2010 7:02 AM   in reply to djones0305
    Just wanted to say thanks. This worked for me, too.
    Dec 10, 2010 7:06 AM   in reply to jchiff
    Good luck!
    Dec 14, 2010 10:57 AM   in reply to MurraySummers
    Do you know where this file/folder can found on a Mac OS 10.6?
    Dec 14, 2010 11:51 AM   in reply to benjaminwo
    <user>/Library/Application Support/Adobe/Dreamweaver CS5/en_US/Configuration/MacFileCache-XXXXXXX.dat
    Aug 3, 2012 8:35 AM   in reply to MurraySummers
    This has not worked for me....Im on a PC with XP using CS5.5
    Aug 3, 2012 8:41 AM   in reply to rlsdesigns
    What are your symptoms, and what did you try?
    Aug 3, 2012 9:10 AM   in reply to MurraySummers
    found this info for XP
    Dreamweaver CS5.5: C:\Documents and Settings\Your User Name\Application Data\Adobe\Dreamweaver CS5.5\[language]\Configuration
    I followed this and deleted the WinFileCache file...RE-booted and file still shows up everytime!! ARG!
    Every time I open a page in DW the error pos up....
    Aug 3, 2012 9:40 AM   in reply to rlsdesigns
    Wait - you delete the winfilecache file, and after rebooting it's there again?  Do you look BEFORE, or AFTER starting DW?
    Aug 5, 2012 8:44 AM   in reply to MurraySummers
    The error is still there assuming the file isn't.
    Aug 5, 2012 9:34 AM   in reply to rlsdesigns
    Is the file still there?  What are your error messages?  Is it the same error every time.  Is it true for all sites?
    Aug 6, 2012 4:16 AM   in reply to MurraySummers
    Well, actually the file is still there...deleted it again, tired to open a page (true for ALL sites), error appears, look in the configuration file again and a NEW WinFileCasche-xxxx has been created......DWerror_2012aug.jpg
    Aug 6, 2012 4:21 AM   in reply to rlsdesigns
    Every time you restart DW, it'll create a new file cache although the name will be different.  That's why I asked if you looked BEFORE or AFTER starting DW after a reboot.  Are you sure you are deleting the file that is in the correct location?
    Jan 19, 2014 6:03 PM   in reply to rlsdesigns
    Hi rlsdesigns,
    I have exactly the same problem and error message even though my setup is slightly different (- Win7Ult, 64 bit, CS6).  I've tried deleting the WinFileCache in User\AppData\Roaming\Adobe\DeamweaverCS6\en_US\Configuration and rebooted, whatever, but still get the error saying onOpen is not defined.
    I just wondered if you'd subsequently found a solution please?
