What do I need to change/add to, to this css, to be able to adjust my image size?
.section img {
height: auto;
width: auto;
max-width: 100%;
I have tried to make some of my pictures larger/smaller and have been unable to. I'm assuming it has to do with my css.
Thank you for your help.
Melody
Not sure I understand your question.
Image size is typically described in your HTML code.
<img src="some_image.jpg" width="xxx" height="xxx">
If you want to make images that re-scale with the page layout, you must put them inside a liquid (% based) container and drop the width & height attributes from your HTML code.
For better help, we will need to see a link to your test page.
Nancy O.
I want to change the width and height to specific sizes.
I will do this, adding the width and height I want, but I am not seeing any changes.
Thank you.
Melody
<. . > Point Heavenward Siamese
www.pointheavenwardsiamese.com
"Unto You I lift up my eyes, O You who dwell in the heavens." Psalms 123:1
http://pointheavenwardsiamese.com/GeishagollSiamese/females.php On this page (for example) the top picture I would like to make just a bit bigger...but the BOTTOM PICTURE...it is WAY too big. I've tried adjusting that in my html width and height...but there was no change.
Thank you Nancy.
Actually, I put that there and it is needed - along with a lesson on how
to make images for web pages. Without that rule, if Melody adds images
to her site that are larger than her layout, the layout will break and
she will wind up with either float drop or images that extend past the
boundaries of her container.
Al Sparber - PVII
Dreamweaver Menus | Galleries | Widgets
I have to second Nancy's suggestion. Just one oversized image (reduced in scale by CSS/HTML) can make your page seem unloadable on a slow connection.
For example: A 1MB jpeg file that is ~12" across is resized by CSS to be ~3" across in it's display size. Even though the display size has been reduced, it's still 1MB and adds over 5 minutes to the download time on a typical 56k modem connection.
I'd been helping Melody. She is a very sweet person. What I did was to
fix her site. She somehow wound up with an HTML5 DOCTYPE without a fix
for old IE was wondering why her site did not display styled in IE8. So
I kept the DOCTYPE, but got rid of the unsupported tags.
Next, we dealt with images. What she has is what she has. Melody has
neither image editing experience not an image editing application. So
she was manually changing height and width attributes on every image tag.
She wanted a gallery, but her images are so drastically different in
size and aspect ratio, that an open source solution was out of the
question. So I gave her a copy of IGM2 and set up a test gallery for her:
http://pointheavenwardsiamese.com/GeishagollSiamese/test.htm
I set up the embedded gallery at fixed height so the images would not
scale out of site, but gave her a full-Screen mode icon so that viewers
could switch to full-screen mode and see all images at their full
natural size.
The biggest problem is that Melody is managing her site through her
hosting company's control panel and is therefore unable to really use
Dreamweaver's more powerful features. When she makes a change to her
site, she has to copy the code from Dreamweaver and paste it into the
control panel. This has caused numerous corruptions.
So, I just wanted you to have an overview so that if you find yourself
answering her questions, you go gently. She kind of needs a guardian
angel at this point to walk her through things with the most important
thing being to teach her how to connect Dreamweaver to her server.
Al Sparber - PVII
John Fritz,
What you are saying is not relevant to the actual situation. The woman
has no image editing capabilities. She is using the height and width
attributes of the image tag as her only means of image editing. She
needs someone kindhearted enough, and with enough time, to walk her
through the fundamentals of web design and of using Dreamweaver.
Al Sparber - PVII
The Finest Dreamweaver Menus | Galleries | Widgets
Since 1998
