I'm editing XDCAM-EX footage on a new 2.4 GHz Intel Core i7 with 8GB memory tethered to a thunderbolt display. My hard drives are on 800 firewire. My playback consistantly strobes and as the day winds on it gets slower until I have to reboot at which point when powering down the system always crashes and I have to do a hard restart. Playback is fine for about 15 minutes after start up.
I'm really enjoying the CS6 interface but considering returning to FCP7 or AVID with this project so I can SEE and HEAR what I'm cutting!
Anyone having similar issues?
Patrick
ps Mercury playback is on & 6GB are set aside for Premiere.
Try changing the MPE mode to Software and see if the issue continues. Also try moving the material off the FW drive to the local drive and disconnect the FW drive. Create a test project with Hardware MPE mode on and import some of the material. See if it continues. This definitely is pointing to a caching issue corrupting the frame buffer. It however is a matter of isolating where the caching issue is occurring from.
Eric
ADK
Hi Eric - Changing the MPE mode to software worked. That's why you haven't heard back from me in 24 hours as I was able to complete the project. Can you explain to me what might have happened and how to determine what MPE setting to use? We have numerous premiere stations that will be running in the next months.
Patrick
Well there could be several things causing this.
1. Heat of the GPU is getting beyond normal/stable temps. This is very common on laptops especially with GPU acceleration. Most GPU's today have a thermal point in the 95C range. However they get real unstable in the mid 80's.
2. The ram of the system in general is not enough to handle the application usage and the hardware acceleration caching besides the shared ram used for frame buffer. 8GB of ram is honestly really low for the Adobe with hardware MPE on and HD. There is allot of ram being used for the caching of GPU acceleration data since that is how GPU acceleration works. Based on the info above, it sounds like you are reaching a point where the shared frame buffer block of ram is getting used and corrupted by the GPU acceleration blocks of ram. The GPU acceleration memory allocation is going to fluctuate based on caching set by Adobe and also the amount of Frame data/ material caching. I would say this is the most likely issue that you are running into. However the only way to test that is increase the ram and then try the hardware MPE again. BTW the real minimum amount of ram you should have with hardware MPE and HD is 12 to 16GB depending on platform. Any less and you will likely run into problems.
3. Video driver has issues with the current GPU acceleration in use. This could be the case if you running into a driver that has a different Cuda/Opencl version than what Adobe is using. That is easy to check by verifying the last version Adobe has tested with.
4. Last is a bad stick of system ram or a bad video card/GPU chip on the board. This is a possibility however you would likely be seeing other issues with the OS or other applications if so.
Hope that helps.
Eric
ADK
