Prem Hessenkamp
Pls rate my Production Premium PC : )
Aug 3, 2012 9:43 AM
Tags: #hardware #production_premium; #pc_build;
Intel® Core i7-3770K, 4x 3500 MHz
Mainboard (1155):
ASUS P8B75-M, 1155, Intel® B75 Chipsatz
RAM
16384 MB DDR3-RAM
1.
1000 GB, Seagate®/Western Digital®, SATA
2.
500 GB, Seagate®/Western Digital®, SATA
Grafik:
NVIDIA GeForce GTX 570, 1280 MB GDDR5, 2x DVI
Netzteil:
350 Watt Silent-Netzteil
Soundkarte:
onBoard HD Audio 7.1
1. Laufwerk:
24x ASUS Multiformat DVD-Brenner
    Aug 3, 2012 10:10 AM   in reply to Prem Hessenkamp
    A 350 watt power supply is totally inadequate.  The minimum system requirement if you have a GTX 570 is 550 watts and even that is probably marginal
    Aug 3, 2012 10:20 AM   in reply to Prem Hessenkamp
    Look at eXtreme Power Supply Calculator Pro v2.5 and get the Pro version. Put your system load at 100% and capacitor aging at 30%, then add some safety margin to the calculated wattage and calculate that you will add some extra disks, fans, etc. in the future.
    Aug 3, 2012 10:56 AM   in reply to Prem Hessenkamp
    Prem,
    In addition to what Bill and Harm stated, ditch the B75 motherboard for a Z77 motherboard: The B75 chipset does not allow the CPU to be overclocked at all, which almost completely negates the very advantage of a K-series CPU with unlocked multipliers. In fact, all motherboards using the B75 chipset has all of the CPU speeds permanently locked to stock speeds.
