I have used this little tutorial for opening a new browser window before:
http://alt-web.blogspot.co.uk/2012/03/create-pop-up-window-in-dreamwea ver.html
It worked a charm. So I found it out again to do the same job, only this time <A> onclick and all its <A> buddies are not in the menu. They were there the last time I did this, and the tut expects them to be there,
I have checked on my previous use of this behavior and the only difference I can see is that I clicked on an image and not text to trigger it all off.
I have just managed it again by using a logo in the sentence, but what is going wrong when I try text?
Cheers
Just choose 'onClick' from the list
When you select an image the 'A onClick' appears in the list BUT does not if you just use text as a link. Both are the same and do the same job. What DW is really saying is - apply the link to the 'anchor' tag which surrounds the image. When no image is present it doesnt need to as the link will be attached to the selected element, which is the anchor tag.
Thanks for that, but when I go with onclick alone, replacing javascript:() for the original link still allows a new tab to open in addition to the nbw.
I assumed this was because <A> onclick was missing, as this is the only difference with the text link and the linked image process which works fine?
What does your link look like (similar to the below)?
<a href="Javascript:()" onclick="MM_openBrWindow('http://www.bbc.co.uk','','width=500,height=500')">link</a>
and the <script> at the top of your page (similar to below)?
<script type="text/javascript">
function MM_openBrWindow(theURL,winName,features) { //v2.0
window.open(theURL,winName,features);
</script>
I don't get any new browser tabs opening, just a pop up window.
Nancy O. wrote:
Thanks I can see now, but my tut did not tell me that.
It does in step #10:
- Go back to the Properties Panel (Fig. 4) and replace the first URL in the link field with javascript:() This makes the primary link into a null link so the page doesn't open twice.
Nancy O.
I actually did that probably 6-7 times. I only got it to work by editing the url myself as advised. Spooky.
Thanks.
