tomash3dfx
Problem with popup menu :(
Aug 3, 2012 3:30 AM
Tags: #menu #popup #ray #blu
Hi, I have problem with my menu.
I create simple menu in photoshop ( two buttons PLAY and SCENES), http://www.endokrynologwalcz.pl/encore/4.jpg
motion background I create in AF and convert it to .mpg file.
I have set Background time line in menu, I have set popup menu.
http://www.endokrynologwalcz.pl/encore/main.jpg
http://www.endokrynologwalcz.pl/encore/main2.jpg
And when I going to Preview my project I can't see menu.
http://www.endokrynologwalcz.pl/encore/3.jpg  (no buttons PLAY and SCENES)
http://www.endokrynologwalcz.pl/encore/2.jpg
In Flowchart I try right click at menu pop up and preview from there but I get message GENERAL ERROR.
http://www.endokrynologwalcz.pl/encore/error1.jpg
http://www.endokrynologwalcz.pl/encore/error2.jpg
I check project and as usual one problem "Title remote not set" but nothing else
What can I do?  PLEASE HELP me...
    Aug 3, 2012 10:39 AM   in reply to tomash3dfx
    I don't think it is relevant, but go to the Flowchart view, click on the starting disk, and in the properties panel, set the "title button" to something. That will remove the "title remote not set" warning.
    Aug 3, 2012 10:47 AM   in reply to tomash3dfx
    You cannot preview popups in Encore. Your buttons are only on the popup?
    Aug 4, 2012 6:53 AM   in reply to tomash3dfx
    I am confused about what are menus and what are video/timelines. But I see now that you have an intro timeline (as first play), its end action is another timeline, then its end action is the "menu video." (Which appears to have an end action of itself. It is set to loop forever? You might also set its end action to stop.)
    Your popup is set to the timeline "Menu Video." And while that timeline is playing, you should see it. How long is that timeline?
    FYI, in your response in this forum, it you use the camera icon to insert pix, they will be visible without clicking on them.
    Aug 5, 2012 1:57 PM   in reply to tomash3dfx
    I do not see you click to "popup" on the remote in VLC player. Are you?
    Aug 5, 2012 2:56 PM   in reply to tomash3dfx
    I can't find a way to execute the popup menu in VLC. Is there one? Jim, you out there?
    In Total Media Theater, no problem.
    Ultimately, you need to burn a test disk to check it. I use DVD+RW.
    Aug 5, 2012 4:32 PM   in reply to tomash3dfx
    Oops - of course I meant BD+RW, not DVD, which will not run a popup.
    Use your bluray build to folder that you used for VLC. Play with TMT. TMT has a popup button. Try that.
    Aug 6, 2012 12:04 PM   in reply to tomash3dfx
    Does the video already have audio?
    Aug 6, 2012 12:05 PM   in reply to tomash3dfx
    Excellent!
    Aug 6, 2012 3:20 PM   in reply to tomash3dfx
    Because now I can just select which audio is playing.
    That is correct; only one audio track can be active at a time. So you create two audio tracks in Premiere: one without music (as you have now) and one with. Then you put the plain one on audio one (as you have now) and the audio + music on the Encore timeline as audio 2.
