Joseph Anthony T
Premiere CS4 Freezes while loading a specific project
Aug 3, 2012 10:51 AM
Tags: #adobe_premiere_pro_cs4 #load_project_freezes
I've looked everywhere for the anwser to this and I've tried everything, I just really want this project file to be fixed/uncorrupted if it is.
Alright so I have Premiere cs4 on Windows 7 and its working fine it opens new projects and mostly all of my old ones besides this one project I have. This project is 14.9mb (I know thats pretty large, but I've been working on it for a while now) and everytime I try and open it the load project window comes up and it freezes at around 95% of the way. I can still move the load project window around but if I press cancel then Premiere turns white and doesn't respond.
This is a common problem that I have found but I haven't found a solution that works for me.
Here's what I've tried:
Restarting my computer
clearing prefences
clearing cache
changing file names (so it brings of the media offline, but it never gets that far)
reinstalling premiere (almost worked, now it gets to about 95% instead of like 75%)
unplugging external hard drives (once again to get the media offline window, but it doesn't come up)
using xml wrench (I'm not to familar with this program but I've tried to use it)
Is there any hope? I don't have any usable autosaves either I just really want to fix this corrupt project that I've been working on for over a year now.
    Aug 3, 2012 11:02 AM   in reply to Joseph Anthony T
    To try (may or may not work) is create a new project and import the old project into the new
    Aug 4, 2012 7:28 AM   in reply to Joseph Anthony T
    how many external drives are you using ? is the project resources on the external drives ?
    are you running out of hard drive space on your boot drive and externals ?
    what kind of connection to your external hard drives ?
    my gut feeling is you're having a hardware problem maybe.. although it could be some software problem, but it might be good to eliminate what problems might be happening one step at a time sorta... like see if it's hardware ...and if NOT then deal with it as if it is a software problem.  unfortunately fixing things usually means eliminating potential causes in a methodical way and it takes time.
    also you'd need to supply tons of info about how your system is set up and stuff like that...or everyone is just guessing without any info to focus on particular potential solutions...
    good luck !
    Aug 4, 2012 10:33 AM   in reply to Joseph Anthony T
    Based on other messages I've read, USB2 may cause problems... you need USB3 or eSata externals for video editing
    Aug 5, 2012 12:03 PM   in reply to Joseph Anthony T
    im sorry to say this problem is beyond my ability to understand what could be wrong and help you...but just thought I'd let you know I looked at the post and others will also look at it, and see if they can help. so dont think nobody is thinking about it and trying to come up with a way to help out.
    I see some things you might consider changing for future use of editing program in general , but at this point its moot.. for your current problem. In other words, no sense closing the barn door after the horses have run off... with regard to those particular horses.
    I have to hope that someone else here can help you, especially with that mssg from dynamic link which is interesting... but I dont use after effects so am no use to you.
    sorry, but my advice is limited to checking stupid stuff that would take a lot of time to look into..and probably has nothing to do with your real problem...I'm coming up blank with suggestions to even begin to troubleshoot the problem.
    Hopefully someone else will have a brain storm...
    sorry you're having trouble, and good luck !
