Problems with Videomerge
Aug 2, 2012 1:13 PM
Tags: #problem #help #video #windows_7 #premiere_elements_10 #elements_10 #videomerge
I've been having problems getting the videomerge effect to work. I have several clips that are on a black background. Usually, clips on a solid bankground are prompted to add the effect, which it is not telling me. Also, I've tried using the eyedropper tool, and it still doesn't remove the black, even after adjusting the tolerance. I can't seem to get anything to work. Is there something I'm doing wrong? I am running Premiere Elements 10 on Windows 7 if that helps.
    Aug 2, 2012 3:10 PM   in reply to ParadoxProduction
    Hard to say exactly what's going wrong when we don't know exactly what you're doing, Paradox.
    I'm not sure what you mean by "clips on a solid bankground are prompted to add the effect, which it is not telling me." You can also manually apply Videomerge by selecting it in the Effects panel or by right-clicking on the clip and selecting the Videomerge option.
    Are you putting your clip that you want to remove the background from on Video 2 and the new background on Video 1, directly below it on the timeline?
    Again, any details -- or even better a screen capture image -- can help us help you.
    Aug 3, 2012 11:21 AM   in reply to ParadoxProduction
    I wonder if the ChromaKey Effect will get you what you want. Just Key out the black, and test.
    Good luck,
    Hunt
    Aug 3, 2012 12:28 PM   in reply to ParadoxProduction
    Great news!
    Premiere often offers several ways to do something. Depending on the Source Footage, and also on what one wants to do, another workflow might yield better results.
    Good luck and happy editing,
    Hunt
