What is wrong with my website?
Aug 3, 2012 1:33 PM
Tags: #help #images #ftp #carousel
Ok i watched this video on adobe tv its called the basic layout and navigation in dreamweaver part 15 and i did excatly what i was supposed to do but when i uploaded my site it doesnt look like its supposed too. When i preview in dreamweaver it works perfectly but now that its on the web it looks different some words don't show in the carousel div, i have the image gallery that doesn't work right but everything else is ok the video box i have up works and the links it's just those two things bascially. I don't know what wrong please HELP!!!!!!!!!!
    Aug 3, 2012 1:39 PM   in reply to PrincessKeesha91
    Please post a link to the page in question.
    Aug 3, 2012 3:46 PM   in reply to PrincessKeesha91
    Can you be specific about what is not working for you?
    Aug 6, 2012 10:00 AM   in reply to PrincessKeesha91
    Your csscarousel.css is not uploaded for starters...
    Aug 6, 2012 10:24 AM   in reply to PrincessKeesha91
    There are a lot of other errors on the site. You'll need to fix them first, they could be the culprit, but it's hard to say how a browser is going to act with errors in the HTML and CSS.
    Run the site through these and clear out any errors first...
    http://jigsaw.w3.org/css-validator/
    http://validator.w3.org/
    The csscarousel.css is still not coming up correctly. I'm guessing there is an error there too.
    Aug 6, 2012 10:57 AM   in reply to PrincessKeesha91
    PrincessKeesha91 wrote:
    when i put in the carousel it reads 0 errors found
    I'm guessing this is just uploaded to the wrong spot. According to your site, a file named "csscarousel.css" should be in a folder called "css" that is on the same level as your index page. It should be at "http://genpackaging.com/css/csscarousel.css" however, according to your server, it isn't there a 404 error comes up instead.
    Some validation of CSS will show -moz-"whatever" is an error because it's not "technically" part of CSS3. Those are fine.
    As for using the HTML validator, you should only have to paste in the web address. It then lists all of the issues with an explanation and the line that they show up on in your code. Here is the link with your site added, there are 66 errors (most of which will be fixed after the first couple are taken care of):
    http://validator.w3.org/check?uri=genpackaging.com&charset=%28detect+a utomatically%29&doctype=Inline&group=0
    Aug 6, 2012 11:04 AM   in reply to Jon Fritz II
    Ah, your server is case sensitive.
    The link in your page to the csscarousel.css file needs to be changed from
    css/csscarousel.css
    to
    CSS/csscarousel.css
    Check all of your other links to ensure they all have the proper capitalization. If you have something linking to the "SpryAssets" folder, but you have it set as "spryassets" in the link, it won't read it due to your server settings.
    Aug 6, 2012 11:26 AM   in reply to PrincessKeesha91
    Ok thank you very much its working like it's supposed to now! THANK YOU!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    it's always the smallest problems...very annoying.
    I hear you. You may want to talk to your server admin and see if something can't be done about that. Right now, if someone had their caps lock turned on while trying to type in a URL on your site, it would not come up.
    GENPACKAGING.COM/STORE.HTML doesn't exist right now (404 error), but genpackaging.com/store.html does
