Attempting to encode the following video via AME CS6 and am currently running into the following problems:
-- When encoding at 30fps (H.264/mp4) -- the duration of the file is correct, but the audio/video runs super fast and sticks on the last frame of the video for the remaining time left.
-- When encoding at 15fps (3gp)-- the duration of the file and the audio/video are correct, but is very low quality.
-- When encoding at anything in between (H.264/mp4), the video stutters all the way through.
Very confused as to what is going on. I am simply looking to encode/compress the video in a high quality mp4 file. Any help would be greatly appreciated.
Format : AVI
Format/Info : Audio Video Interleave
Format profile : OpenDML
File size : 30.1 GiB
Duration : 57mn 14s
Overall bit rate : 75.2 Mbps
Video
Format : RGB
Codec ID : 0x00000000
Codec ID/Info : Basic Windows bitmap format. 1, 4 and 8 bpp versions are palettised. 16, 24 and 32bpp contain raw RGB samples
Duration : 57mn 13s
Bit rate : 73.8 Mbps
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate : 30.000 fps
Bit depth : 8 bits
Bits/(Pixel*Frame) : 8.005
Stream size : 29.5 GiB (98%)
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : 1
Duration : 57mn 14s
Bit rate mode : Constant
Bit rate : 1 411.2 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Bit depth : 16 bits
Stream size : 578 MiB (2%)
Interleave, duration : 502 ms (15.06 video frames)
Interleave, preload duration : 502 ms
Hey Jim, thanks for walking me through but I'm not seeing the Microsoft AVI option in my presets.
Screenshot: http://i.imgbox.com/acjQ2Xre.jpg
