I used to have this problem once in a while with CS5, though not sure why it was only occasionally. I cannot see any format image that I open in CS6. The file opens fine - no error message - and then the screen is just blank. This used to be an Edit>Preferences>Performance issue, where I would uncheck the Enable Open GL Drawing box and all was fixed. But there is no such box in this new version.
I did try: Open>Preferences>Performance, and changed the Advanced Settings to Drawing Mode = normal. But no results.
Thanks for your help.
You may be in a laptop catch-22, where there's not a good solution, because usually you have to get display drivers for onboard GPUs from the laptop maker.
Have you tried the various Graphics Processor settings in the Edit - Preferences - Performance dialog? Try all 3 advanced modes, and you can even fall back to disabling the GPU entirely. Make sure to close and restart Photoshop after changing any settings there and before testing.
-Noel
There is still a GPU, and separate drivers for the GPU.
Go to the GPU makers website and get the latest drivers. Follow the directions (sometimes you have to uninstall old drivers first) to install the new driver. Do not go to Microsoft or the system integrator to get drivers (they're typically years out of date).
I have updated all the drivers now and the problem is resolved. But it took a call to Dell technical support. It was worth resolving the issue, I suppose. For future viewers, I'm on a Dell XPS17 with a combo CPU/GPU. The Dell tech support guy updated the NVIDIA drivers and a few other things I didn't follow... you may need to do the same thing if you have a laptop in this series.
