My cs4 production premium serial number wont work. I have uninstalled all adobe softwear and used the clean up tool, reinstaled cs4 but the serial still wont work.
Could it be that I have one licence of cs5 in use on one computer at work? My CS4 came with CS5. The serial number works fine to regester it on the adobe website so I know it is correct. Please help.
UpstartThunder you should be able to locate the AdobePCD and caps folder at C:\Program Files\Common Files\Adobe. I would recommend moving both folders to your desktop and trying the installation again.
If you are utilizing any other Adobe Creative software though I would recommend uninstalling it prior to utilizing this procedure.
Sigh. I seem unable to uninstall cs4 suddenly. I also can't run it (comes up with error 6). I tried the adobe clean up tool and this time it said I had cs4 cs5 cs5.5 cs6? (Nothing had appeared on this before) I said clear all then it didnt do anything, it said done and said the log is in a folder location that doesn't excist.
I uninstalled my flash 8 at the begining of all this and now doubtfull this will even work.
How do I uninstal CS4 now? I have read just deleting the folders is not recomended.
I am sorry UpstartThunder but from your previous messages it appears that you had a message stating you had an invalid serial number. This message will typically come up during the install process. Was this not the case? Were you previously able to install but then received a message that your serial number was invalid?
Did you start having this problem after you moved the AdobePCD and caps folder or did you perform additional steps which lead you to being unable to initate the install process?
Can you please provide the exact error message you receive when trying to install?
No message about invalid serial number, it just wasn't excepting the number. An x to the right of it after you put the number in.
Cs4 installed and uninstalled fine 2 times before, just wasn't excepting the code which I know is correct as it works on the regestering in my Adobe.
Yes I started having this trouble after moving the AdobePCD and caps folder. I have put them back and still no joy.
I havent tried reinstallying it as it is presently installed and I am unable to uninstall it using the windows uninstal program or the adobe clean up tool (which didnt seem to do anything).
I have error 6 when trying to open cs4.
I am fully aware Vista is poo, I am upset ![]()
Thanks for your help. How do I uninstal CS4 now?
I see I would verify that your CS4 serial number is registered at http://www.adobe.com/. This will help verify that the serial number itself is not the issue. If you are unable to use the Clean Script then your last chance would be to try running the Microsoft Fix-it utility at http://support.microsoft.com/mats/Program_Install_and_Uninstall/.
