"There is no disk in the drive. Please insert a disk into drive D:"
Aug 3, 2012 11:12 AM
Tags: #cs5 #help #windows_7
Hello,
I'm having a dialog box pop-up showing "There is no disk in the drive. Please insert a disk into drive D:" whenever I try to open any of the CS5 applications. This occurs most often with Photoshop and Acrobat. If I click "Cancel" several dozen times the dialog box will go away and I can proceed to using the programs.
This only happens when I use an Adobe product.
Any ideas how I can correct this problem?
Mark
    Aug 3, 2012 11:29 PM   in reply to R80o
    Your software was never properly installed and the programs are attempting to run a "post-install install". This can happen when you serialize trial versions and additional components become avialable that were not included in the trial due to licensing restrictions. The simpel answer is: Insert that disk, run as admin and let it do its thing. Otehrwise consider using the Creative Suite Cleaner Tool and starting over.
    Mylenium
