Samen
Photoshop CS6 Text leading problem
Aug 4, 2012 4:25 AM
Hi!
Problem with text editing in Photoshop CS6. Here's an image - a compare between CS3.
In CS6 in editing text mode when select all text & use Alt + keyboard "down" I have too big jumping values of leading. It's really make uncomfortable work to exactly adjustment spacing between the lines in text blocks :(((((....
In CS3 wasn't this problem, everything was excellent with leading & very comfortable work
Is there any fix this problem?
p.s.
OS - windows 7 64 bit
cs6 - 64 bit extended
cs3 - 64 bit extended
  • Noel Carboni
    Dec 23, 2006
    Aug 4, 2012 6:55 AM   in reply to Samen
    Have you tried just using single Up and Down arrow keystrokes in the Leading field?  The point size changes by 1 if you do that - very controllable.
    For what it's worth, when I tried to reproduce what you're seeing, I couldn't get it to do anything useful with Alt-Up arrow or Alt-Down arrow here at all.  Perhaps I misunderstood exactly what state you're in when you're attempting those keystrokes.
    -Noel
