S.O.S.
Jul 20, 2012 6:13 AM
Tags: #help #scoring #actionscript_2 #score_issue #quiz_results #urgenthelp #click_counter #quiz_score
  Latest reply: kglad, Sep 2, 2012 9:42 AM
Replies 1 2 3 Previous Next
  • kglad
    Jul 21, 2002
    Aug 4, 2012 9:32 AM   in reply to CRAAZYGENIUS
    use the trace function to see if that code is executing.  if it's not, check your button names.
  • kglad
    Jul 21, 2002
    Aug 18, 2012 10:39 AM   in reply to CRAAZYGENIUS
    add:
    this._parent.completeF(1)
    to the last frame of a question swf when answered correctly and
    this._parent.completeF(0)
    to the last frame of a question swf when answered incorrectly.
    and, to your main swf, add:
    var scoreVar:Number=0;
    completeF(scoreVar);
    // create a score dynamic textfield (say score_tf) to display your score.
    function completeF(n:Number):Void{
    scoreVar+=n;
    score_tf.text=scoreVar;
  • kglad
    Jul 21, 2002
    Aug 19, 2012 5:56 PM   in reply to CRAAZYGENIUS
    no.
    depending on the quiz taker's response, you know whether that response is correct or incorrect.  use that to determine which value to pass to this._parent.completeF().
  • kglad
    Jul 21, 2002
    Aug 20, 2012 6:52 AM   in reply to CRAAZYGENIUS
    explain the setup of a typical question swf.
  • kglad
    Jul 21, 2002
    Aug 20, 2012 9:24 AM   in reply to CRAAZYGENIUS
    will the wrong animation be the same for every question?
    will the correct animation be the same for every question?
  • kglad
    Jul 21, 2002
    Aug 21, 2012 7:00 AM   in reply to CRAAZYGENIUS
    then create a wrong.swf and a correct.swf.  your scoreF can load the appropriate swf.
    you alread have created the question swf's, true?
    if yes, do you have something in each swf that determines what is the correct option that a user should click?
  • kglad
    Jul 21, 2002
    Aug 21, 2012 11:14 AM   in reply to CRAAZYGENIUS
    for question1, how does flash know B is the correct choice?
  • kglad
    Jul 21, 2002
    Aug 22, 2012 6:16 AM   in reply to CRAAZYGENIUS
    is there anything in question swfs that make each different other than the question, the choices and the answer?  ie,are there graphics in that differ in the different question swfs?
  • kglad
    Jul 21, 2002
    Aug 22, 2012 8:59 AM   in reply to CRAAZYGENIUS
    then you'll need to hardcode the correct answer into each question swf.
    if your buttons are named, A,B,C,D, you can use:
    for question1 swf:
    var correctAns:Button = B;
    A.onRelease=checkAnsF;
    B.onRelease=checkAnsF;
    C.onRelease=checkAnsF;
    D.onRelease=checkAnsF;
    function checkAnsF():void{
    if(this==correctAns){
    this._parent.completeF(1);
    // use attachMovie to display "correct.swf"
    } else {
    this._parent.completeF(0);
    // use attachMovie to display "wrong.swf"
  • kglad
    Jul 21, 2002
    Aug 22, 2012 10:19 AM   in reply to CRAAZYGENIUS
    attached to the first frame where those buttons exist.
  • kglad
    Jul 21, 2002
    Aug 22, 2012 9:55 PM   in reply to CRAAZYGENIUS
    void should be Void
  • kglad
    Jul 21, 2002
    Aug 23, 2012 6:54 AM   in reply to CRAAZYGENIUS
    what's the trace function show:
    function checkAnsF():Void{
    trace(this+" "+correctAns+" "+this._parent);
    } else {
  • kglad
    Jul 21, 2002
    Aug 23, 2012 10:36 AM   in reply to CRAAZYGENIUS
    } else {
  • kglad
    Jul 21, 2002
    Aug 23, 2012 11:53 AM   in reply to CRAAZYGENIUS
    put that code in your first question swf attached to the first frame where those buttons exist.
    then click one of your buttons in the test environment.
  • kglad
    Jul 21, 2002
    Aug 23, 2012 5:41 PM   in reply to CRAAZYGENIUS
    what's this show:
    trace("test");
    } else {
  • kglad
    Jul 21, 2002
    Aug 25, 2012 7:06 AM   in reply to CRAAZYGENIUS
    again
  • kglad
    Jul 21, 2002
    Aug 26, 2012 10:18 PM   in reply to CRAAZYGENIUS
    then that code is not executing.  ie, you're not testing the file with that code or you have not added that code to a frame that plays.
  • kglad
    Jul 21, 2002
    Aug 27, 2012 6:58 AM   in reply to CRAAZYGENIUS
    at this point it doesn't matter whether they are external swfs.
    that code needs to be in the same swf as the one that contains your answer buttons.  if it were and you were testing correctly you would see trace output.
  • kglad
    Jul 21, 2002
    Aug 28, 2012 9:59 PM   in reply to CRAAZYGENIUS
    then if that frame played, you would see trace output.
Actions
