Hi guys, I'm trying to get my head around the AnimatorFactory class for the first time and keep hitting errors.
Essentially what I'm trying to do is create a game involving bugs moving around the screen. Simply straight line tweens weren't the kind of movement we wanted, so I hunted around and found the function that allows you to convert a pre-designed motion tween into AS3 code for you to use.
I've created an AnimationManager class to store the details of all the possible Motions, and each new instance of a bug is randomly assigned one of these motion paths when their 'go()' function is called. Here is the function:
public function go():void
_myMotion = _myAnimationManager.getAnAnimation();
_myAnimFactory = new AnimatorFactory(_myMotion);
_myAnim = _myAnimFactory.addTarget(_myBug, 1);
_myAnim.addEventListener(MotionEvent.MOTION_END, motionFinishHandler);
_myMotion is an instance of the Motion class, _myAnimFactory is an instance of the AnimationFactory class, _myAnim is an instance of the AnimationBase class. _myBug is a simple MovieClip that is a child of the class conatining the go() function. All variables are protected class variables.
The code compiles fine but when it runs I keep getting this error:
ReferenceError: Error #1069: Property instance454 not found on code.game.mobs.SmallFly and there is no default value.
at fl.motion::AnimatorBase$/processCurrentFrame()
at fl.motion::AnimatorFactoryBase/addTargetInfo()
The "instance454" thing seems to refer to the _myBug variable. I don't understand why this should be not found? The SmallFly class is simply a subclass of my generic "Bug" class which contains this go() function.
Good idea. Tracing the name returns the exact same name as the one in the error message :/ (In the last test run I did it was instance441 rather than instance454, but that is irrelevant I think). It is this line that is triggering the error:
Arg, Flash hurts my brain some days.
Incidentally, I have just tried reverting back to my old basic tweening method and it works perfectly, _myBug is appearing and functioning as normal. So it shouldn't be the source of the issue. I know this problem is all going to be cause by some tiny misunderstanding but I honestly can't get my head around it just now.
Great minds think alike, I just tried that. Same problem.
I also tried commenting out the 'problem' line (e.g. _myAnim = ...), just to see if it was possibly the line before causing the error and Flash was mistakenly thinking it was the line after, no errors.
Finally, I tried making _myBug a public var (trying anything now haha) and still the same issue.
I'm not sure if this is progress or not, but I came across a post which said that display objects created dynamically couldn't be used with the AnimatorFactory. So I tried putting an instance of the image I want to move on the timeline of the SmallFly class, and got this error instead:
TypeError: Error #1009: Cannot access a property or method of a null object reference.
at fl.motion::MatrixTransformer$/getSkewX()
at fl.motion::Animator/setTargetState()
at fl.motion::AnimatorBase/set target()
at fl.motion::AnimatorBase/play()
at fl.motion::AnimatorFactoryBase/addTarget()
Hmmm... If I use trace(_myAnimFactory.toString()); on the line after it is created I get a compiler error saying that there is no "toString" method (Call to possibly undefined function through reference with static type fl.motion.AnimatorFactory), even though it is listed in the official documentation.
