CS6 Issues Mountain Lion
Aug 4, 2012 9:10 AM
Tags: #mac #cs6 #mountain_lion
I am running the latest version of Photoshop CS6 on my mid-2010 13 inch Macbook Pro with 8gb of memory. Mountain Lion is the OS. Whenever I launch CS6 it crashes with the following message: An unexpected and unrecoverable problem has occurred. Bridge opens fine.
    Aug 4, 2012 9:16 AM   in reply to JohnD5633
    We need to see the entire crash report (the long, detailed one) to know why it is crashing.
    Aug 4, 2012 9:30 AM   in reply to JohnD5633
    Looks like the Lens Profile database is corrupt and causing problems when Photoshop tries to read it and check for updates.  (and it tries to throw an uncaught exception on a thread - we're testing a fix for that part so it won't crash)
    Aug 4, 2012 9:47 AM   in reply to Chris Cox
    Sorry, I was reading the code to find the location of the databases/caches.
    Try trashing the file ~/Library/Application Support/Adobe/CameraRaw/LensProfiles/1.0/pscache.dat
    When you next open the LensCorrection plugin, it'll take a few seconds to update the cache and database, then should work as usual.
    Aug 4, 2012 10:06 AM   in reply to JohnD5633
    The crash report says the same thing as the first one, just on a different thread number, so you don't need to repost it.
    Hmm, it's the Lens Profile update thread that's throwing an exception.  Unfortunately it crashes while trying to recover from the error, not at the site of the actual error.
    It could be the index.dat file (one directory level up).
    Or it could be an error in the OS URL handling when it tries to get the information from the website.  But if that's the case other things would probably be breaking as well.
    Darn.  So far I can't reproduce the problem by corrupting or removing those files.  So I'm really not sure where the problem is really coming from.
    Aug 4, 2012 10:21 AM   in reply to JohnD5633
    Yes, it's one directory level up from the pscache.dat file.
    But so far corrupting those files hasn't lead to a crash or error.  I'm still not sure how the original error occurs.
    Aug 4, 2012 10:37 AM   in reply to Chris Cox
    Have you tried resetting or deleting Photoshop's preferences?
    Aug 4, 2012 11:35 AM   in reply to JohnD5633
    cmd-opt-shift on launch, or go delete ~/Library/Preferences/Adobe Photoshop CS6 Settings/Adobe Photoshop CS6 Prefs.psp
    Aug 4, 2012 3:58 PM   in reply to JohnD5633
    JohnD,
    Did it ever open, so that you could Activate it? If not, then it should not have Activated yet.
    Good luck,
    Hunt
    Aug 4, 2012 6:59 PM   in reply to JohnD5633
    No, that should not require you to activate again.
    I'm at a loss.
    We've reset the prefs and the files that feature reads, so I'm not sure what else could cause it to throw exceptions (that wouldn't also cause the rest of the computer to misbehave).
    Aug 5, 2012 1:02 PM   in reply to JohnD5633
    You can try reinstalling, but I have no idea if it'll help.
