How do I correct in an existing client site, DW 8 menu drop downs that are not visible in MS Vista?
Aug 3, 2012 5:31 PM
An existing web site: see page sample here- www.fwgraphicdesign.com/GardensatPalisades/index.html does not show the drop down menu items for each menu choice. they work fine in Firefox, Safari, Chrome, but not Vista. What do you sugest, and is there a fix?  Pages are created in Dreamweaver 8
    Aug 3, 2012 5:36 PM   in reply to fvrw
    Drop down? or do you mean flyout from the menu items?
    And by Vista, do you mean Internet Explorer? and if so, which version are you using?
    Aug 3, 2012 5:44 PM   in reply to fvrw
    Vista is probably the operating system... so do you mean Internet Explorer browser?
    From the browser main menu, click "Help" and then "About" to find the version of Internet Explorer.
    Aug 3, 2012 6:24 PM   in reply to fvrw
    Well it works fine in IE8... so we need to narrow this down a little.
    First, validate your page code here:
    http://validator.w3.org/
    There are 2 major error related to the menu.
    Fix those and then test in Adobe Browser Lab to zero in on the exact version of IE that is the problem.
    https://browserlab.adobe.com/en-us/index.html
    Best of luck!
    Adninjastrator
    Aug 4, 2012 8:53 AM   in reply to fvrw
    Well the flyouts look fine in IE8 and 9.... so that leaves possible issues with much older version...6 and/or 7. Their market share is pretty small now a days...
    I don't have either of those old browsers so I really can't test... sorry..
    That menu looks like it was build around a rather old, convoluted method... may be rather hard to fix. If you really want to target those old IE browsers, then you might want to just redo the menu with straight css.
    Tons of free examples on the internet:
    http://www.cssmenus.co.uk/flyout.html
    http://www.cssplay.co.uk/menus/example_flyout.html
    Best of luck!
    Adninjastrator
    Aug 4, 2012 9:26 AM   in reply to fvrw
    Well, there a couple of things wrong.
    Problem #1:  Missing document type.  Without a valid doc type, the page runs in Quirks Mode which confuses many browsers - especially IE.
    Solution:
    • Go to Modify > Page properties > Title/Encoding > Doc Type >
    • Select a doc type that matches your code: (XHTML 1.0 Transitional).
    • Hit Apply, OK.  Save.
    • Repeat with other site pages.
    Problem #2:  MM Rollover Menus.  Possibly the worst menu system ever created, it's not too surprising that they don't work well in all browsers. You can read the sordid story about them below:
    http://losingfight.com/blog/2006/08/11/the-sordid-tale-of-mm_menufw_me nujs/
    Solution:
    Get rid of the awful MM Rollovers and replace them with a CSS menu system.
    Good luck!
    Nancy O.
    Aug 4, 2012 9:28 AM   in reply to adninjastrator
    When you say this -
    You are being too kind.  That menu approach (legacy code from Macromedia days) has been thoroughly debunked even by the author of the code (read this to see - http://losingfight.com/blog/2006/08/page/3/).
    And when you say -
    You have understated the case!  Get rid of those nasty menus!  They have NO redeeming value - really....
    Aug 4, 2012 10:11 AM   in reply to MurraySummers
    Thanks for the comments Murray! LOL!!
    Aug 4, 2012 10:12 AM   in reply to Nancy O.
    @Nancy - I had to look around on Andy's blog to find the right link.  It has changed to the one I just posted.
