jemmabean
Where do I locate the programme now I have downloaded it?
May 31, 2012 3:07 PM
I've just installed the trial run of premier pro cs6 but now I can't locate the programe?
Where do I search/look for it?
Help me!
I can't find it
    May 31, 2012 3:20 PM   in reply to jemmabean
    What is your Operating System (Mac, PC, Linux etc.)
    This will help us in helping you find Premier Pro CS6
    Zach
    Jun 2, 2012 2:28 PM   in reply to ZDreier
    By default it is downloaded to your User folder.
    Jun 2, 2012 6:48 PM   in reply to Jeff A Wright
    i'm having the same issue with the download.  I am using a Mac.
    Aug 4, 2012 11:24 AM   in reply to asav44019
    downloaded the trial version of premiere cs6. it says that it was installed successfully and ready to use. however, i could not find the program in the list of programs in my start menu & even on my desktop. tried to locate through folder search but aside from the dloaded folder with the setup file, the program icon is not there that may enable you to launch the program directly. apparently, i checked my 'programs & features' from my control panel for uninstalling a program, & 'adobe premiere pro cs6' was there. help!
    Aug 4, 2012 11:46 AM   in reply to innovative92
    Did you check Start>All Programs?  If it is not listed there then you should be able to find it installed in C:\Program Files(x86).
    Nov 19, 2012 3:43 PM   in reply to Jeff A Wright
    I am having the exact same problem, have downloaded and installed the premiere cs6 twice now, it say it has installed but I cannot find it in the start menu, program file, or anywhere else. All i have is a file with that name with files inside but no programme. Help!
    Nov 19, 2012 3:49 PM   in reply to catwojcik
    Catwjocik your next step would be to review your installation logs to see if there was an installation error which may have prevented the install from completeing.  You can find details on how to review your install logs at Troubleshoot with install logs | CS5, CS5.5, CS6 - http://helpx.adobe.com/creative-suite/kb/troubleshoot-install-logs-cs5 -cs5.html.
    Nov 20, 2012 2:57 PM   in reply to Jeff A Wright
    Thanks Jeff, I did as you and the instructions said. There were not fatal errors or errors just this...
    warning DW064: Memory requirements not met for {7176B973-6011-43C1-AEBC-2D73FE7C6982} Adobe Premiere Pro CS6 Family 6.0.0.0
    Does that just mean I don't have enough memory then? I have found the programme in my control panel if I go to add or remove programs but can't open it. Do you think I should remove it and start again once I have made some space on the memory? thanks, CW
    Nov 20, 2012 2:59 PM   in reply to catwojcik
    Catwjocik I would first verify that you meet or exceed the system requirements for Premiere Pro.  You can find the system requirements at http://www.adobe.com/products/premiere/tech-specs.html.
