problem installing cf9 or cf10
Aug 03, 2012 Aug 03, 2012
I have cf8 installed on windows7 using the built-in sever. I have tried to install cf9 and cf10 using both the built-in server on port 8501 and using my installed apache web sever. I always get the result, can't connect.  I have installed and uninstalled many times to try all the different possibilities.  I have uninstalled cf8 and tried the installs using the built-in server on port 8500.  I have re-installed cf8 and it works fine.  Every log I look at says that everything is fine.  I have tired the services to start automatically and manually.  I do not know what to try next.  Any suggestions would be greatly appreciated.
972
The CF forum is your friend....
Mylenium
Adobe Employee ,
Moving this discussion to the Cold Fusion forum.
Aug 04, 2012 Aug 04, 2012
After I have uninstalled Apache and all coldfusion and rebooted, I have installed cf10 using the built in server.  When I click on administrator on the start menu and  try to go to http://localhost:8500/CFIDE/administrator/index.cfm, get a response of Firefox can't establish a connection to the server at localhost:8500.  It will do this whether I stop or start the coldfusion server.  None of the logs show any errors.  If I uninstall cf10 and reinstall cf8, cf8 works correctly.  Anybody have any ideas what to try next?
Aug 08, 2012 Aug 08, 2012
Which logs were you looking at (which exact files)?
Are you certain CF10 is listening on 8500?  (set in [CF directory]\cfusion\runtime\conf\server.xml)
Adam
Documentation
