InDesign Help | InDesign Crashes with Blank Dialog Boxes on MacOS 10.7.4
Jul 13, 2012 1:22 PM
Replies 1 2 Previous Next
    Jul 13, 2012 1:22 PM   in reply to Community Help
    What about for CS 5.5? The folder names don't work -- when you get down to UI.InDesignPlugin there is no folder with that name, therefore I can't seem to locate the idrc_PNGA folder.
    Jul 13, 2012 1:27 PM   in reply to moriabane58
    Post the screen shot of you file directory , it has worked for almost everyone.
    Jul 13, 2012 1:30 PM   in reply to moriabane58
    My mistake. I was looking for a folder called UI.InDesignPlugIn, not a folder called Application UI.InDesignPlugin.
    The fix is working for me on a mid-2012 13" non-retina MacBookPro running 10.7.4 and Adobe InDesign CS 5.5.
    Thank you.
    Jul 13, 2012 2:02 PM   in reply to Community Help
    This worked for me. Thanks!
    MacBook Pro with Retina Display running InDesign CS6 and 10.7.4
    Jul 15, 2012 1:01 AM   in reply to Community Help
    Works for me, too. Thank you!
    MacBookAir (Mid 2012), ID CS6, Mac OS X 10.7.4.
    Jul 15, 2012 1:14 PM   in reply to Community Help
    10.7.4 MacBookPro just purchased one week ago -- ID5 crashes when I try to Package anything. Will this fix that?!?!   Will there be an official software update for this issue soon???
    Jul 15, 2012 1:17 PM   in reply to fiddles5
    Yes , It may work if you are having the same problem as others.
    Our engineering team is looking for a simpler method to fix the issue but yet not sure that official software update will include the fix for this or not.
    Jul 15, 2012 2:01 PM   in reply to fiddles5
    yes - this fix worked!  thank you so much! Back to work...
    Jul 16, 2012 9:40 AM   in reply to Community Help
    Will this workaround work with an older Mac? I'm having the same crash problem when trying to export a PDF in InDesign CS6. I am using a Mac, Software version 10.7.4, and early 2009 iMac. I rely on InDesign CS6 for my work daily and this is exasperating.
    Jul 16, 2012 10:15 AM   in reply to Robert Terry
    @Robert,
    Please post a separate thread about your problem. This fix is very specific to 2012 Macs.
    Jul 16, 2012 11:30 AM   in reply to Community Help
    Why in the world is this not just a standard update that could be applied using Adobe Application Manager? This kind of a fiddly fix seems amateur. :\
    Jul 16, 2012 11:35 AM   in reply to thirdopticaltool
    We are still working on getting it structured properly , this fixed has worked for the CS5 and CS5.5 but many people using CS4 are still facing the issue.
    Jul 16, 2012 11:38 AM   in reply to thirdopticaltool
    Would you really want to wait for that?
    Sheesh! There’s no pleasing some people!
    Jul 16, 2012 12:01 PM   in reply to Community Help
    I have Utilities.InDesignPlugin but no UI.InDesignPlugin
    Also, within that folder, I seem to have no idrc_PNGA. I have idrc_BOSD, CLST, FACT, PVER, SCML AND VRLS but no PNGA.
    Ideas?
    Jul 16, 2012 12:08 PM   in reply to CAlyanak
    Which version of Indesign are you on ?
    Jul 16, 2012 12:11 PM   in reply to Manish-Sharma
    CS6 Version 8.0
    Jul 16, 2012 12:13 PM   in reply to CAlyanak
    Look under "Application UI.InDesignPlugin" not UI..InDesignPlugin
    Jul 16, 2012 12:15 PM   in reply to Manish-Sharma
    Awesome. Thanks. However, you might want to put 'Application UI.InDesignPlugin' with quotes or something. My eye did not catch the 'Application' because of the space.
    Thanks again.
    Jul 16, 2012 12:17 PM   in reply to CAlyanak
    Thanks for feedback will do it.
    Jul 16, 2012 10:13 PM   in reply to Community Help
    Is this fix available for InDesign CS4 6.0.6?
    Have this same problems exporting to pdf with a lot of docs (but not all of them!).
    Jul 17, 2012 2:37 AM   in reply to vincentp62
    Not yet, but they're working on it...
    Jul 17, 2012 8:56 AM   in reply to Community Help
    Thanks - worked on a MacBookAir 13" 2012 and InDesign 5.5
    Jul 18, 2012 10:45 AM   in reply to Community Help
    How do you remove the installation of the MacOS Mid 2012 Software Update for 10.7.4?
    Jul 18, 2012 5:15 PM   in reply to Community Help
    Apple provides MacBook Air and MacBook Pro Update 1.0.
    Dose this update fix this problem?
    Jul 19, 2012 6:15 AM   in reply to Norio Kawamura
    Unfortunately, no. But thank you for the suggestion!
    Jul 19, 2012 6:25 AM   in reply to Sunny In Texas
    @Sunny In Texas ,
    you can roll back by restating your machine with "Ctrl + R"
    Jul 26, 2012 7:18 AM   in reply to Community Help
    upgrade to Mountain Lion. Solves the fix.
    Aug 4, 2012 7:42 AM   in reply to caseyctg
    I did both solutions and still, it didn't work. inDesign CS 5.5 doesn't even open anymore.
    I just bought a macbook pro and upgraded it to OS X 10.8
    What should I do?
    Aug 4, 2012 8:13 AM   in reply to Luiza Ribeiro
    Which solutions would that be? Did you follow the instructions at InDesign Help | InDesign Crashes with Blank Dialog Boxes on MacOS 10.7.4
    What is happeing when you try to open ID CS5.5? Please be very specific.
    Aug 15, 2012 7:25 AM   in reply to Peter Spier
    Yes I did follow both solutions.
    When I tried solution 1, it says "this updated is not needed for OS 10.8 or later".
    And then, I tried solution 2. I followed the post exactly the way it explains. So what's wrong...
    So I click on indesign, and then it takes a while to load, and then it quits.
    Then, this appears:
    Process:         Adobe InDesign CS5.5 Re: InDesign Help | InDesign Crashes with Blank Dialog Boxes on MacOS 10.7.4
    Path:            /Applications/Adobe InDesign CS5.5/Adobe InDesign CS5.5.app/Contents/MacOS/Adobe InDesign CS5.5
    Identifier:      com.adobe.InDesign
    Version:         7.5.3.333 (7530)
    Code Type:       X86 (Native)
    Parent Process:  launchd Re: InDesign Help | InDesign Crashes with Blank Dialog Boxes on MacOS 10.7.4
    User ID:         501
    Date/Time:       2012-08-04 18:18:21.759 -0300
    OS Version:      Mac OS X 10.8 (12A269)
    Report Version:  10
    Interval Since Last Report:          4424 sec
    Crashes Since Last Report:           1
    Per-App Interval Since Last Report:  37 sec
    Per-App Crashes Since Last Report:   1
    Anonymous UUID:                      ABD1A8E4-568D-4300-91EB-2791AF5F3E4C
    Crashed Thread:  0  Dispatch queue: com.apple.main-thread
    Exception Type:  EXC_BAD_ACCESS (SIGBUS)
    Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000038
    VM Regions Near 0x38:
    --> __PAGEZERO             0000000000000000-0000000000001000 Re: InDesign Help | InDesign Crashes with Blank Dialog Boxes on MacOS 10.7.4 -/- SM=NUL  /Applications/Adobe InDesign CS5.5/Adobe InDesign CS5.5.app/Contents/MacOS/Adobe InDesign CS5.5
        __TEXT                 0000000000001000-0000000000005000 Re: InDesign Help | InDesign Crashes with Blank Dialog Boxes on MacOS 10.7.4 r-x/rwx SM=COW  /Applications/Adobe InDesign CS5.5/Adobe InDesign CS5.5.app/Contents/MacOS/Adobe InDesign CS5.5
    Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
    0   dyld                               0x8fec18d3 ImageLoader::isLinked() const + 11
    1   dyld                               0x8febf4d3 NSLinkModule + 102
    2   libdyld.dylib                      0x962a0303 NSLinkModule + 87
    3   com.adobe.InDesign.Font Manager     0x10bfdbc8 TINglue_version + 792
    4   com.adobe.InDesign.Font Manager     0x10bfe5cf TIN_Startup + 177
    5   com.adobe.InDesign.Font Manager     0x10b84329 GetPlugIn + 17705
    6   ObjectModelLib.dylib               0x011381a1 0x111f000 + 102817
    7   ObjectModelLib.dylib               0x01138abb 0x111f000 + 105147
    8   ObjectModelLib.dylib               0x01147396 0x111f000 + 164758
    9   ObjectModelLib.dylib               0x01157c1d ShuksanInit(IStartupScreen* ()(), IPlugIn) + 23101
    10  ObjectModelLib.dylib               0x01153244 ShuksanInit(IStartupScreen* ()(), IPlugIn) + 4196
    11  com.adobe.InDesign                 0x00002842 main + 82
    12  com.adobe.InDesign                 0x000027c6 start + 54
    Message was edited by: Peter Spier
    Aug 4, 2012 2:41 PM   in reply to Luiza Ribeiro
    Looks like a problem with SING. See SING Removal
    Aug 4, 2012 2:46 PM   in reply to Peter Spier
    Thank you. I'll try it.
    Aug 4, 2012 3:44 PM   in reply to Luiza Ribeiro
    Thank you for the advice! Removing MARK ll worked perfectly!
    Aug 15, 2012 7:16 AM   in reply to Community Help
    Is there a fun for CS4?
    Aug 15, 2012 7:26 AM   in reply to megan.scherer
    A "fun"? If you meant "fix," then not yet, as far as I've heard.
    Aug 15, 2012 7:28 AM   in reply to Peter Spier
    Yes, I meant fix. Another great thing about the new MBPro is the odd autocorrect.
    Sep 5, 2012 5:21 PM   in reply to Community Help
    I developed this Blank Dialogue Box just today.  Yesterday, ID worked fine.  I'm running ID CS6 on OSX Mountain Lion 10.8.1.
    I went to the recommended FIX page and downloaded Fix #1:  CopyiconRsrcdePrimpt1.app.  BUT now this app won't open because "it came from an unidentified developer."  ...how now???
    However, they seem to be working on it with Apple.  Meantime, I CAN get into ID by simply opening a previous file.  Everything works fine, except there is no dialogue box.  I'll wait for the update - but not too long.....
    Sep 14, 2012 10:03 AM   in reply to Community Help
    ok, help! I don't seem to have a folder at all for idrc_....
    I'm Applications/Adobe InDesign CS6/contents/MacOS/Required/Application UI.IndesignPlugIn/ Versions/A/Resources and all i have listed is:
    Application UI.rsrc
    Info.plist
    PkgInfo
    I used the search tool on Finder for idrc to triple check myself, and the only thing it's finding are the fixes i just downloaded.
    help...
    Sep 14, 2012 10:13 AM   in reply to buffybellenir
    SIKE! it shows it now... weird thanks universe
1 2 Previous Next
