Openssl: No certificate matches private key
Aug 4, 2012 11:54 AM
Tags: #ios #distribution #p12 #openssl
This used to work on my last computer, but I created a CSR and uploaded it to Apple and it returned a valid distribution certificate. But when I run Openssl to try and create the p12 file, I keep getting the error:
"no certificate matches private key".
My batch file looks like this:
set OPENSSL_CONF=C:\OpenSSL-Win32\bin\openssl.cfg
set RANDFILE=.rnd
openssl x509 -in ios_distribution.cer -inform DER -out developer_identity.pem -outform PEM
pause
openssl pkcs12 -export -inkey mykey.key -in developer_identity.pem -out myfile.p12
pause
I've tried just about everything, and I'm seriously stuck. Can anyone help?
    Aug 4, 2012 11:58 AM   in reply to MakaiMedia
    You can run into such issues if you still have old certificates kicking around. Go into Keychain Access and look at Certificates and My Certificates. Any that don't have a key next to them are likely to not work, but still cause problems. Of the others, delete any that are not the latest date, and export a P12 from the most recent one, to use in Flash.
    Also, make sure that your provisioning files are using that latest certificate.
    Aug 4, 2012 3:13 PM   in reply to MakaiMedia
    I put together a series of tutorials on creating the Apple CSR request and certs on Windows a while back. They have step by step instructions including the commands I used. See if that helps, it can be tricky for sure.
    http://www.youtube.com/playlist?list=PL57C122F59F8F1A43
    iBrent
    Aug 4, 2012 5:14 PM   in reply to MakaiMedia
    Yes, I'm sure it matters. Listen to iBrent, he makes sense. At least he did once a couple of years ago, though I think that was a fluke.
    Aug 4, 2012 6:01 PM   in reply to Colin Holgate
    Fluke is as fluke does. ;-)
